i can't get the twitter panel to work i had config it from the twitter setting but when i use the panel it reports:
error:rss error fetching feed system.exception: error fetching http request the remote server returned an error(404)
Tic Tac Toe
— Play Tic Tac Toe with your ARC robot: configurable turn, win and draw scripts, cheat commands and optional speech-recognition control.
There is no read twitter panel. There is a SpeakTwitter EZ-Script command. The issue is with twitter, not ARC. They are discontinueing the RSS feed request. If there is an alternative, it will eventually be supported.
Reference: https://brodiesnotes.blogspot.ca/2012/10/has-twitter-killed-rss-feeds-yet.html
Please use proper titles for your subject or you will be banned, again. The title you used has been renamed.
