Slide Script icon Slide Script — Adjust a numeric variable via slider (0-1000) with customizable min/max, center button and scripts triggered on value change or bonus button press. Try it →
Specific Recommendation For Power Adapter
Hello, I made the leap after a fair amount of research and bought an ezbv4 last night. My initial application is static so I deferred buying a battery..unless I missed it I did not see a wired power adapter in the store. I have read some of the power tutorial.. I did get the power base also.
I am looking for a recommendation on finding a power supply.
I expect to eventually run 18 micro servos and possibly up to five brushed motors. Three of these are larger and draw 1.8a stalled.. I never expect to have all the servos running at once.. I plan to have the. Brushed motors running through escs so their power can be drawn from another source. If you follow.
I want to make sure I have something soon.. So to start I could use a dc wall wart say 12 volt 2amp with 2.1 mm barrel?
Can someone throw out some links to recommended sources? I am inclined to go to one of the mote prominent online robot shops. Does that make sense?
@Jeremie
Wouldn't it make more sense to put the smoothing Cap's across the supply to the Servo's, as it's the servos that are causing the current spikes! I know you will have to have a higher voltage rating for the Cap's.
Also the rule of thumb is to have the voltage rating of the smoothing caps at least 30% over the supply voltage, your using.
Chris.
#19
@cem The ezb4 browns out because (in my case with my inMoov) the 5v 60 amp meanwell's voltage drops below 4.5 when all the servos start to move... What jereimie has done was use the two 2,5v 1 farad caps to keep just the ezb's voltage above 4.5v so it doesn't brown out. Anyway, it works great. I seen it first hand when I was at ez robot earlier this year,,, DJ was running his inMoov with a 5v 20amp power supply with Jeremie's supercap mod and there were no brownouts...
@Richard, I know this, and think your missing my point? Jereimie suggests putting the Cap's across the power for the digital ports 3.3v, as shown in the photo, and not the main power supply to the Servo's and EZB.
It may work OK the way he suggests, BUT what I was suggesting was to put it across the main power source, obliviously you need to be mind full of the voltage rating of the Cap's to use.
Unless I missing something here? but I do know what I'm talking about, I have been working in the Electronics design industry for over 40 years, and have a degree in Electronic design and engineering, and voltage smoothing is pretty basic stuff!
Chris.
#21
Yep Chris is correct common practice is to use smoothing "tank" caps on the input side which in most cases does the trick, but not in ours unfortunately.
Here's are the reasons:
  1. Servos have a extremely high in rush current demand. In order to smooth out their voltage drop (on the input side) requires a proportionally high amount of capacitance. I literally used every high farad capacitor in my collection (30 or so) placed in parallel (capacitance adds in parallel) to try to smooth out the input voltage and it barely made any positive results. These findings were discouraging because I didn't want to have to chain together a massive bank of caps to rectify the issue.
  2. Voltage rating versus capacitance - capacitor voltage rating needs to be matched or exceed (better practice) the voltage being applied. In the case of using a 7.5V supply you would need at least a 7.5V rated cap. But here's the catch: the higher the voltage rating on a cap the larger in physical size and the more expensive it will be. To use low voltage super caps on the voltage input we would have to place many in series to get up to the voltage rating we need. Here's the next catch: when capacitors are added as the voltage rating increases the capacitance decreases as the farads are being divided, so you have to start paralleling caps to increase the capacitance again. You can see how this could quickly become a ridiculously large bank of caps.
  3. Cost - to acquire large capacitance values these days Super Caps are the answer but to create a large bank of Super caps is very pricey.
  4. Size - a large bank of super caps also takes up space which is usually a commodity in Robots.
All this being said I found it far simpler, smaller, and more economical to place Super Caps on the regulated output side of our SWPS to account for dips on the input voltage side. In Rush voltage dips only happen for fractions of a second so as long as the Supercaps can hold up the 3.3V for the time needed it all works out.:)
#22
Maybe I should throw this info into a tutorial with osilliscopes screenshots lol, seems like a good candidate for one.
#23
Even easier than adding caps why not just bypass the EZB and power the servos directly from the PS (if you have the room and soldering or connector skills). After I stopped using my EZB as a power conduit I've never had power brownout. Either way will work but I guess but I feel the less components in a well designed circuit is better. I feel the real trick is to have a quality PS or battery able to deliver enough amps and wire large enough to transfer them. I'm no educated electrical engineer but I think the voltage sags causing EZB brownouts happen because you're pulling too many amps through the EZB too quickly. Good Power supplies or proper batteries are better equipped and designed to deliver this kind of power draw. So why suck the life out of your EZB. Bypass power around the EZB to other power hungry devices and feed the EZB it's own dedicated power supply.
Anyway, that's my working theory in my robot. I've proven this in my build by using both techniques. I'm not saying caps are the wrong way to go. I'm just offering another option. Too me though caps seem like placing a bandage on a wound to keep the bleeding from happening. ;)
@Jeremie, if you're still doing tests perhaps you could try my method to confirm my findings? Really load the PS down and battle test it by bypassing the EZB to see when the PS browns out vers running supply power to servos through the EZB using caps in the ADC pins?
#24
Hey @Dave,
Thanks for chiming in, you do bring up some valid points! Having proper gauge wire and a good quality power supply are very important in the quest to eliminate brownout conditions. Although, I would contended that it's easier to add a couple caps to the 3.3V than rewiring your entire project for external power, but that might just be my preference:).
What we are really taking about here is the limitations of switching power supplies/supply and demand. If the power supply cannot supply enough current to meet the demands of the application it will drop the voltage to compensate (and cause a brownout) this is the nature of switching power supplies (SWPS). In the majority of the brownout cases the EZ-B's power traces are not to blame, it's is highly likely that it is a case of a power supply that cannot meet the inrush current demands of the motors (DC or servos). How do I know this? Well I can run the same amount of current through the EZ-B with a high Ahr LiPo or Lead acid and it will work without an issue. I have also seen cases where no 2 power supplies are the same (quality matters) 20A doesn't always mean 20A. Meanwell is a brand that I've had great experiences with, their rating is trustworthy.
The only caveat to all this is what the real current (inrush and constant) is for each project. The EZ-B isn't a magic machine it does have a theoretical maximum amount of inrush and constant current it can handle its just hard to nail down. Instaneuos inrush current is very hard to measure and with constant current we are dealing with thermal properties and resistance. That being said, using ezrobot servos I have not found a situation where I cannot power an robot (even with 16 servos) through the EZ-B with a SWPS.
The key for a lot of people is that they want to use a lower current rated supply than is needed due to expense. Adding super caps to the 3.3V line allows you to do this. The real fix is a higher current SWPS (but yeah they are expensive).
