Talk Servo V2 icon Talk Servo V2 — Animate servos to simulate jaw/mouth with ARC text-to-speech; configurable vowel/consonant timing, start sync, multi-servo control, pause/stop. Try it →
Germany
Google+ YouTube
Speech Recognition
hello, my speech Recognition dont works, the Microphon Level are in the middle when i speak. whether German or English, I dictate text box that the robot does absolutely nothing. Do I need to install any language program?
Thank you
Germany
Google+ YouTube
Hello Bravia, Thank you for your answer in have see the Video, in the Speech Recognition Window i dont see the Command. it is black!
Ireland
Ok So your commands are not getting through for some reason. Are you using win7 ? any errors when you first open EZ-B ? if not open "sound recorder" in windows and check microphone does record
Germany
Google+ YouTube
Yes Win7 64bit No Errors when i open my ARC Sound Recorder and Skype works fine
Ireland
in speech recognition in ezb click on setup adjust microphone levels and boost,in advanced tick "allow applications to take exclusive control of this device" Good luck
Germany
Google+ YouTube
Hello Bravio, I have checked their recommendations, but unfortunately it was unsuccessful
Germany
Google+ YouTube
I have testet with another Win7 PC, its the Same.
There are several reasons it's not working - In my case it was the speach recognition app in Win 7 was english based - not American. Once I matched them (same version of English as ARC) it started working. You could have the same problem or one of several others. Do a search and check all the references in this website (use google search) and you will find the answer to your problem. Speach recognition is fun but takes a lot of fine tuning and determination. Good Luck..
