Servo Speed icon Servo Speed — Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved. Try it →
sorry i disagree ,main reason it has at least 1000 modules and interfaces was coomparing the leaf microcontroller to you cpu yours does has some good and bads as leaf microcontroller .like flash is only 80k compare to 512k on leaf microcontroller and same with ram and eeprom much higher 16 channel analog 10 bit compare to 8 channel analog rest it about the same,i dont know whats the speed of your CPU
it sure does. they distribute a bunch of open source libraries with it. doesn't mean ROS is great. it means ROS + opencv + anything else = something neat. But EZ-SDK + opencv + everything else = even better.
Spend some time with EZ-SDK:)
I KNOW ros sortware is used by all the larger robot companies opencv only for vision does synthia have cslu facial emotions ,and ai emotions
DJ here is info on CSLU
CSLU MAIN WEBSITE
also CSLU SOFTWARE CSLU TOOLKIT WEBSITE
do have to be a progammer almost to use EZ-SDK i see about LEAF programming is all done also on EZB i dont see encoders hook up for motor feedback
from what i see there is a lot of people who build robots that are not programmers using like C++ sop thats where the SDK is a problem,now i starting to learn C++ buts its very hard i do know LISP AI software that most AI ROBOT DESIGNERS USE NOW one we use is LISPWORKS,there many other LISP software made for AI ROBOT designs most of the major colleges use LISP SOFTWARE in the robotics classes like FSU
Many large companies use EZ-Robot. More than you think:) And bigger projects than you can imagine;) . Due to the speed and power of the sdk and gui. The gui also supports C# and VB embedded within it. Plus many other features. You can read about EZ-Robot features by browsing the website, or checking the About section to get an idea of what the future has in store:)
Leaf Project is neat. I like it.
havent seen any yet,i meen the $5000 to $100000 designs i have many i can list
will you be asdding more memory to EZB it is super small only 80k ,other like motorola (leaf micro) 512k,and arduino has and basic stamp has added memory chip to it
I'm a more effecient programmer, so 80k is more than enough:) . Sorry, i can't tell you who are largest companeis and supporters are.
#15
DJ, I have a leaf robot also. I absolutely LOVE it. But, I also love the EZBoard and I am SOOOO Excited about Synthia. I absolutely can not wait. Leaf is Phenomenal. But, I really need more. Hope it is soon! and although I like programming, I am not very good or fast at it. So, I hope Synthia will be EZ. I am a A.I. Freak. I really love A.I. and it is the driving force in robotics for me.
So far, I have worked with Lisp, C, Robo-realm, Microsoft's Robotics Studio, and tried very hard to download and conquer ROS. I do good with Ubuntu, but not ROS. Every robot that I have except Leaf is just sitting there waiting. I was thinking once I get QBO in, I will probably have a better time with ROS. That is IF they have a good simple GUI. I have a Turtle-bot, and two extra Roombas that are just sitting there. I don't want them to just go left,right,forward , backwards on my voice command, I want the to autonomously get around. I want them to follow my face, a colored object, movement. But, I have a kinect on them, not sensors. My wife said NO MORE ROOMBA money. So, no sensors. So , you see, I have a delima. It seems that all the programs do ONE job very well. But, what I need is GLUE to glue the subroutines altogether. It has been too difficult for me. Your program is about the EZest of all the systems to understand and operate. I am not as fast as you are, but I can copy examples that you give.
God Bless YOU!! D.J.
thanks, Mel
#16
of all the big major selling robots i have seen (over 50) havent seen yet the EZB support,be a great for sensor and interface support i hope soon they will start using it in the robots for selling
DJ big question on SYNTHIA will it need a programmer like EZ-SDK or easy to use GUI with scripts 80k might be ok for awhile but as stuff is added will need more,also more memory ,you you have faster speed,video take up the most speed and animations needs more speed
MEL ROS is not really hard to use,what good about it is it uses LINUX witch is used in alot of robot designs almost more and maybe more then WINDOWS i have tried mostly all types of robot designs and software ,like ROS ,microsoft robotics,serverbot using a IROBOT CREATE and many many others and built them to compare i know some programming .LISPWORKS,LITTLE c++ I AM LEARING,arduino and basic stamp and few others,looking to learn mostly all soon but electronic designs i am a master at soon as i finish the ezb ROOMBA in few days will make a EZB file for you,then next week after the BROOKSTONE ROVER project since you do have a hard time with making scripts
