Train Vision Object By Script icon Train Vision Object By Script — Train camera vision objects via controlcommand(), attach camera, start learning, monitor progress, and return object name for scripts. Try it →
Germany
#25
ON/ OFF - no problems with any phrases.. all other is not working..
Brazil
#26
Dj.. in my ARC, the only languages that appears in the menu are ENG-EUA and ENG-GB...
I have the 04-20-2015 version...
#27
Can you turn the confidence all the way down to lowest value and try again please
Germany
#28
I tried it.. confidence from 90 till 95..
If I install my desktop pc or notebook in english.. voice recog. is working fine in english. now I use a german computer - I can use long german phrases like: "Meine Mama kann nicht kochen" for ON or OFF and it works.. all other phrases below for the control are not working, there is no response.
do you know a person who use EZ-ROBOT voice recog. in other language ? If you speak another language, try it.
your software is perfect, the best I ever seen. If you fix the problems, you make more money outside the US/UK. I love to speak english, but to fascinated german people the software must understand german. I think its a little bug ^^! because my windows understand all german words.. and your software all english words..
Some more infos
On my laptop running under windows 8.1 (trained to recognize my voice in english and french)
1 Language and speech recognition set-up as US English, ARC OK
2 Language and speech recognition set-up as french language and ARC set for french (no reaction)
using the same program for both language, the only difference I can see in ARC is the sound detection small window is not activated when everything is set up for french.
laptop have been reboot at each steps when switching from one language to the other
have a look at these pic
Germany
#30
@Aerius DJ says: If you use france, you can only activate a servo with france language.. like "robot dit bonjour"
but something goes wrong here and I think its the EZ-Software.
because windows 7 understand me perfectly and try it yourself.. use your notebook in french and change the Enable/ Disable Phrase on top to france words.. it works fine! but ON/ OFF only.
##Carefully said: it makes no sense that ON / Off runs but nothing else. So I think the EZ software has a bug
@ Smarty You are right, after reloading EZ-Buider twice, this time the sound detection windows came on.
And as you have already discover, the system can recognize a french sentence in the enable phrase under Speech rec set-up window.
but can't recognize other french phrase in the list.
I think we are on a right track. Hope DJ this find will help to resolve the problem.
hi guys
is the language only to been seen when you have speech recog on your machien?
smarty are you using win7 ultimate?
