Smart Variable Watcher icon Smart Variable Watcher — Efficient ARC Variable Watcher - lower CPU for large projects; slow initial array render but faster updates; shows name, type, value, length Try it →
Speech Settings
Speech Settings
I upgraded my system to Windows 10 and now in the Speech Settings control only female voice sounds are available. Is there a way to get male voice sounds or is this something Microsoft did? Tell me I'm not stuck with the Irritating British female voice.
@merne Thanks for the link. I have tried to change things there but it won't let me change out of English (UK).
@cem, I just don't like to options given - nothing against the British!
@Bhuston, Bob are you using Windows home version 10 or pro thanks
Also Bob what version did you have before you upgraded to version 10
The reason I ask is because if you have home version they don't have a language pack but if you have the version pro version 10 Microsoft has a language pack only for version 10 pro at least what I've seen on the Internet I'm still investigating I may have to install version 10 which I really don't want to on one of my computers to test
I have the home version and I had 8.1 before.
OK, I got it back to Microsoft David. Some of the speech setting weren't installed with the upgrade. Thanks for everyones help.
@bhouston, nice to hear that it's working again.
#15
I'm reviving this thread because I'm back to the same problem. My computer is set to Microsoft David and the computer speaks with that voice, however, I get a british female voice out of the EZB. I have tried deleting the Speech Settings control from my project and then setting it up again - no change. In fact the EZB speaks with the british female voice without this control added in my project. Anyone else come across this? Any suggestions on how to get a male voice thru the EZB?
#16
It's impossible for SayEZB() to have a different voice than Say() - at least from a code perspective. The two use the same OS function. Except one writes to the sound card and the other writes to a byte stream.
To be clear - are you stating that SayEZB() and Say() are different voices?
-or-
Is the operating system using different voice than ARC?
