Irobot Roomba Legacy icon Irobot Roomba Legacy — Legacy iRobot Discovery and 4xxx control via EZB software-serial (D0), supports Arduino/EZ-Robot, adjustable baud rate; not for hardware UART/USB Try it →
I don't have the Cepstral voices myself so can't check but I know this was mentioned previously and there is something that needs changing in the package to enable the effects.
Have a read of this topic, I haven't had chance to check it over but I'm 90% sure it's the one it was mentioned in.
If not then this one mentioned voices too.
hi all doombot i use the cepstral voice too.there is a program that comes whit cepstral calt swifftalker. there you can make any lines you wanna say .my englich is not very good.but i will try to help. here a little video
also you must use cepstral as you default voice on the pc
Alright dudes! Thanks for your help...got steps from the old thread on how to make the sfx voice into default. Works perfectly. :D
@Doombot> Glad it worked out for you. I really like the Cepstral voice Lawrence using the "old robot" voice effect.
