Miscellaneous Utility Plugin icon Miscellaneous Utility Plugin — ARC utilities: DataQuery for SQL/ODBC/OLEDB/Excel with parameterized queries returning array variables; Ticks/Millis timing functions. Try it →
Welcome to the Ez Robot community
Yes you can simply buy a wireless mike and reciever is plugged into your computer. Ebay is a great place to find a wireless mic and wireless speaker. You could even get a fm modulator and plug it into your pc and buy a fm radio and install it on your robot. We look forward to seeing your project. - Josh S.
Hi jstarne1, thanks for your support, but i no want have robot connected my pc, but really autonomus robot. I can? For a example Sony Aibo (I Have) and Interactive R2-D2 (I have) work without PC. With EZ Robot i can this? Give commands without using the pc? Escuse for my stupid question, but this are my first experience in build robot blush
Dovermann, there are no stupid questions:)
The EZ-B requires a computer because it uses the computer processor. The EZ-B is an extension of your computer. For example, even the Sony Aibo has a computer built-in. The R2D2 does not because it uses a very simple speech recognition chip that barely works:)
All robots in the world that have advanced vision processing and speech recognition are using a PC. Even the NAO robot uses a FIT-PC (https://www.fit-pc.com)
Hi DJ Sures, thanks for informations, mhmmm... i can a fit-PC2i notes and put in my robot... :D But this now are advanced for me. In few days I buy your The Complete Robot Kit and start my adventure in build/custom robot world. Thanks for give me a dream. blush
Good Luck to You, Dobermann!
Welcome to our Group!
:D
Hi, Is there any audio card compatible with EZ-B Controller? I want to avoid multiple channels and make use of the existing capability of EZ-B's bluetooth for transmitting/receiving audio :D
EZ-B works with you computer. If your audio card is working with your computer then it will play when the EZ-B software asks it to.
Hi dschulpius, I'm referring to having a audio-card that can be hooked up into the EZ-B Controller in the Robot so that I can hook up a microphone and speaker to this card.
