Read Digital icon Read Digital — Read TTL digital input from an ARC I/O port; real-time red/green status for low (0V) or high (+3.3/5V), selectable board/port and read interval. Try it →
Spray Paint Disaster
I used a chrome spraypaint to change my robots colour, the one I used is normally used on cars.(I put a primer on first) I did a really good job, let them dry and stored the bits in a box individually wrapped in plastic to protect them.
I unwrapped them today to put some decals on and the paint is all scratched on certain parts, I rubbed it with my finger nail and it scratches easily... what have I done wrong?
Gutted, now I'm gonna have to remove all the paint and start again:( right now my motivation has been destroyed, not looking forward to removing that paint!
Before
after
For plastics you can use etching primer. It chemically glues to the plastic and then use rustoleum brand chrome paint and then cover it with spray epoxy. I prefer cutting steps out when I can. Sometimes you can get lucky and find rustoluem epoxy paint which it much tougher and doesn't require s protective top coat. I used epoxy white on squeegee.
Be careful with a clear coat over chrome paint. I did that once. The chrome paint looked perfect; it was like a mirror. I put clear over it to keep it that way, but as soon as it went on it turned to flat grey. I then read the cans more carefully. I don't remember now if the clear said not put over chrome, or the chrome said not to use clear, but it was stated somewhere not to do it.
Here are a few pictures. For the two large lights, I used milk jug covers painted silver. I used gloss black Rustolium Plastic paint, with Duplicolor Chrome paint over it. It is hard to see in this picture, but they look pretty good. This is where I had the trouble with the clear coat over it though. I had to soak them in paint thinner, clean them off and start again. I have had no problems with peeling, wrinkles, etc.
If you are interested, the torso itself was painted with Rustolium Textured Metallic over automotive primer.
@Danger Gotcha! Thats why I recommended resin spray. I do it a lot, I build custom guitars and I make metallic finishes that way...chrome base, transparent paint on top, then resin clearcoat. The clear is not exactly paint, but polyester resin thats thinned enough to spray. It dries like a shell, so crappy basecoats are somewhat forgiven. It also fills in imperfections.
If you want to see my work:
www.ikoncustoms.com
If not sorry for the spam.
Thanks for the tip @Doombot. Maybe I'll try that. I would like to protect it from dulling, without ruining it again. PS. Your link didn't work. I would like to check it out.
#15
Some clear is really horrible and milky. If you use spray epoxy or jewellers epoxy it's 95 percent clear and you don't need to spray a thick coat on. If you hold the can 12 to 16 inches away and mist like I did on my snakeskin paint job it leaves a thin Matt finish. You can gloss it over if you want but Matt will look closer to the original finish.
Best suggestion would be to try out Rustoleum Hammered Metal. I used it on all my costume pieces to make it look like metal. It has a awesome texture ans is a rugged scratch resistant finish.
Cheers for the advice all...
And thanks @Rich for the step by step instructions you gave earlier and all the other advice you've given me.
@Danger, I ordered some rustoleum clear paint already so I will be careful and only do a small area first to see if it reacts with the chrome. I'm gonna rub it down so it's nice n ruff and then respray the original chrome spray and then a layer of the clear paint. It's the cheapest option at the minute seeing as I already have a few tins left, If that fails I'll take the advice @Doombot gave and try the resin spray. Nice guitars by the way Doombot, would love that job lol I used to repair musical instruments so can appreciate the work thats put into them;)
@Danger just copy the link and paste it to your browser bar. By the way I like the retro looking light fittings on your robot:)
@jstarne1 I may try that paint if all else fails with the chrome I have:) Thanks for the help and advice.
