Chromium icon Chromium — Configurable Chromium browser skill for ARC: navigate URLs, print, open in PC browser, maximize/restore, set page content to a global variable. Try it →
The Problem is not the hardware, when I connect the SSC32 to a local comport it works fine with Script-commands. ComOpen, ComWrite ..... will work.
The Problem is the SSC32-Control in ARC witch will not connect to a local comport.
I think it is a Bug in the SSC32-Control of ARC.
So it sounds like you want to control the SSC32 with ARC through a port directly from your computer and not a port off the USB? I pretty sure you can not do that with natively with ARC.
Dave is right the ARC control needs an ezb v4
Yes, with EZ-Robot controller it works fine, but in the Settings of the SSC32-Control you can selct a local Port. The Comort will not be saved with the Project and it will not work.
The software still requires a connection to the ezb for the software to work. This is because the framework for moving servos and controlling I/o is dependent on an ezb connection.
Hello DJ Sures,
your a right, with an active connection to the EZ-B V4 it works fine.
There ist another Bug, I had to edit the Projectfile with the Editor, the comport will not be saved.
" <SSC32> <Paused>false</Paused> <IsEZB>false</IsEZB> <baud>38400</baud> <port>COM9</port> <usMax>2000</usMax> <usMin>1000</usMin> </SSC32> "
Thansks to all for your help! Hansi
I'll definitely have the saved com port looked into, thanks!
