Roomba Tones icon Roomba Tones — Deprecated Roomba control; replaced by the iRobot Roomba Movement Panel for updated movement control. Try it →
Ssc32 In Mobile Interface
Hi,
I have been using an ezb-v4 with a ssc32 to control servos without issue for a while now. However, trying to use the Mobile interface (v2017.02.16.00) the ezb/ssc32 link (uart @115200) is freezing (red light on both ezb and ssc32) as soon as I try to send a command via the uart. (It will still control the servos plugged directly into the ezb)
I tried clicking the Ssc32 control on the desktop of the mobile and it says: "This control does not have an interface".
Has anyone else experienced weird connection issues when using uart?
P.S. this also happens when I swap the battery in the robot on the Win10 desktop version of ARC . In order to reconnect, I have to shut down the application and restart.
Any assistance would be greatly appreciated.
You need to initialize the port first.... I do it in an init script. Also make sure you add the SSC-32 control to your project as well... I have not tried using the ssc-32 with a mobile device however, just on a PC...
UartInit(0,0,115200)
Quote:
P.S. this also happens when I swap the battery in the robot on the Win10 desktop version of ARC. In order to reconnect, I have to shut down the application and restart.
In general, losing power on the bot should not cause EZ-B to lock up, it should just disconnect, but it is best practice to hit the disconnect button before powering down the bot (to change battery, or any other reason), to make sure that any ongoing communications are shut down, and to re-run your initialization when you power back up and connect.
Thank's for that. I've added the script to the "connection established cmd" (as well as added an init control) and that seems to have solved the PC connection issue. Hasn't resolved the Mobile interface. I even tried adding a button with said script and no dice...
@srobert It's possible the ssc-32 control does not work with the mobile interface....
