Myo Gesture Armband icon Myo Gesture Armband — Map Myo armband gestures and accelerometer to servos and ARC scripts for arm-mimic control; supports multiple armbands. Try it →
It's easier to write the i2c commands in ez script than arduino. What does your arduino sketch do? I can help tell you to use the i2cwrite() instead of the arduino equalevant
Without one to test with, I can't write the code
@DJ I was just looking at the 8x8 matrix control that you wrote. Which would be the easy way out for a non-programmer:) I'm just starting to look at code both arduino and EZ-script. At this point all i can do is take someone elses code and play with it and learn by cause and effect. As for my Arduino program all I did was modify the Adafruit example sketch to display a couple eyes looking around.
The 8x8 matrix we had one to test with. So with this I'm unable to create a control that goes into ARC for thousands of users without knowing if it works:D
I can help you port the arduino code if you can share the commands that you'd like me to replicate.
I also should add that jeremie has an oled ezbit which we will be announcing soon
Your too kind! Let me muck-about Maybe i will learn something in the process:)
@SteveB Just as DJ mentioned we are working on an OLED ezbit which will be SSD1306 protocol via I2C, so you'll be seeing a control soon:)
You guys are awesome!
