Rafiki Front Bumber icon Rafiki Front Bumber — Rafiki front bumper plugin: reads 4 proximity sensors via serial, updates ARC variables, blocks motor movement toward detected obstacles for SLAM Try it →
Stabilizing Frequency Detector on Rock Pi X
Stabilizing Frequency Detector On Rock Pi X
Running ARC directly on a Radxa Rock Pi X (Windows, WiFi) mounted in a small rover. I’m using the Frequency Detector skill to move a pan servo on an EZB v4 over WiFi when a 440 Hz tone is played (tuning fork or phone tone generator). In the skill config, I set Min 200 Hz / Max 1000 Hz, mapped to D0 with servo Min 30 / Max 150, and I also set the variable output to $detectedHz. Windows default recording device is the Rock Pi X 3.5mm headset mic input (TRRS). Enhancements (AGC/Noise Suppression) are off, Exclusive Mode off, tried 16bit 44.1 kHz and 48 kHz.
The issue: the frequency readout jumps around (e.g., 430-470 Hz) even with a steady 440 Hz sine from 10 cm away, and the servo jitters constantly. Min/Max in the skill quickly widens, implying it’s seeing extra peaks. If I switch to a USB condenser mic, it’s better but still drifts a few Hz and occasionally spikes. The waveform looks reasonably clean, but numeric output is still bumpy. I understand multiple frequencies cause noise, so I muted all playback to avoid feedback and tried moving the mic away from the Rock Pi’s tiny speaker; still jittery.
I tried smoothing with a JavaScript loop that reads the skill’s variable and averages it before moving the servo:
let samples = [];
function loop() {
  const f = getVar("$detectedHz");
  if (typeof f === "number" && f > 0) {
    samples.push(f);
    if (samples.length > 8) samples.shift();
    const avg = samples.reduce((a,b)=>a+b,0)/samples.length;
    const clamped = Math.min(Math.max(avg, 200), 1000);
    const pos = Math.round(30 + (clamped - 200) * (120 / (1000 - 200)));
    Servo.setPosition("D0", pos);
  setTimeout(loop, 50);
loop();
Questions: Is there a recommended way within the Frequency Detector to set a minimum amplitude/peak lock or add median filtering, and are there known Windows/driver tweaks specific to the Rock Pi X headset mic that help produce a more stable singlefrequency read for servo control?
Rock Pi X by Radxa
ROCK Pi X runs Synthiam ARCx as an onboard x86 robot brain for browser control, vision, voice, scripts and EZB I/O.
Servos ✕
ADC ✕
Digital ✕
Variable Watch by Synthiam
Live view of script variables, types, sizes and values for debugging; auto-refresh, hex view, pause/clear; may affect program performance.
Control two continuous servos for bidirectional robot movement with speed sliders, configurable ports/stop values, testing and brake/coast options.
Yes - what you’re seeing is very common for pitch/frequency detection on a small Windows SBC like the ROCK Pi X, especially when using a headset/TRRS mic input and driving a servo directly from the raw detected frequency.
A few important points:
What’s likely happening
  • 440 Hz is not a perfectly stable "number" in real-world detection
    • Even a clean tone will fluctuate a few Hz because of:
      • mic noise
      • room reflections
      • input gain variation
      • FFT/windowing resolution
      • harmonic overtones from the source
  • The Frequency Detector is looking for the strongest peak in the audio window.
    • If a harmonic or noise spike briefly becomes stronger, the readout can jump.
  • On a Rock Pi X Windows headset mic input, the audio path can be a little less stable than a dedicated USB microphone.
Best approach in ARC
1) Add filtering in your script, but use median + deadband, not just average
Averages help, but median filtering is usually better for spike rejection.
Your current script also has one issue: setTimeout(loop, 50); is not supported the same way in ARC JavaScript. Use ARC’s sleep() in a loop instead.
Here’s a better pattern:
let samples = [];
let lastPos = -1;
while (true) {
  let f = getVar("$detectedHz", 0);
    samples.push(f);
    if (samples.length > 7) {
      samples.shift();
    let sorted = samples.slice().sort(function(a, b) { return a - b; });
    let median = sorted[Math.floor(sorted.length / 2)];
    // Ignore tiny changes to prevent servo jitter
    let pos = Math.round(30 + ((median - 200) * (120 / 800)));
    if (pos < 30) pos = 30;
    if (pos > 150) pos = 150;
    if (Math.abs(pos - lastPos) >= 2) {
      Servo.setPosition(d0, pos);
      lastPos = pos;
  sleep(50);
2) Add a deadband
If the servo is moving for every 1-degree change, it will chatter constantly.
Try:
  • only update servo if the new position differs by 2-5 degrees
  • or only update if the detected frequency changes by more than 5-10 Hz
3) Limit the detector range more tightly
If you are only targeting A4 = 440 Hz, don’t let the skill search too broadly.
Instead of:
  • Min: 200
  • Max: 1000
Try something like:
  • Min: 390
  • Max: 490
That reduces the chance of harmonics or unrelated peaks taking over.
4) Use a better microphone if possible
You already noticed this:
  • USB condenser mic = better
  • TRRS headset mic = more drift
That’s a strong clue the problem is mostly the input chain, not ARC itself.
For tone tracking, a USB mic with:
  • stable gain
  • good sensitivity
  • low noise
  • no aggressive Windows processing
will usually outperform the built-in headset jack.
About "minimum amplitude / peak lock / median filtering" in the skill
At the moment, the best practical solution is usually to do the filtering outside the skill, like you started doing.
I’m not aware of a built-in peak lock or minimum amplitude threshold option in the Frequency Detector UI that would fully solve this by itself. If you need that behavior, the best ARC path would be to create a custom robot skill that performs:
  • amplitude thresholding
  • frequency confidence scoring
  • median/average smoothing
  • servo deadband
If you want, you can build that in ARC using the robot skill SDK: https://synthiam.com/Support/Create-Robot-Skill/Overview
That would let you make a more "locked" detector tuned exactly for your rover.
Rock Pi X / Windows tweaks worth checking
These can help, especially on the headset input:
Windows microphone settings
In Windows Sound settings for the input device:
  • disable Enhancements
  • disable AGC / auto gain if present
  • keep Exclusive Mode off if it’s causing instability
  • try both:
    • 44.1 kHz
    • 48 kHz
  • test which one gives the most stable pitch readout
Reduce system audio interference
  • mute system sounds
  • make sure no app is using the mic in the background
  • keep speaker playback physically isolated from the mic
Prefer a USB mic with known stability
For frequency tracking, this usually makes the biggest difference.
For servo control, I’d suggest:
  1. Let Frequency Detector detect the tone
  2. Read $detectedHz
  3. Apply:
    • median filter
    • deadband
    • update rate limit
  4. Move servo only when the filtered value is stable
That gives you much smoother motion than binding servo motion directly to raw frequency updates.
One more thing: your servo mapping
If the goal is to move the servo based on tone presence rather than exact frequency precision, consider mapping confidence/stability instead of raw Hz if you can derive it in your logic.
For example:
  • if frequency stays within 435-445 Hz for several samples, move servo
  • otherwise hold position
That often feels much more stable than trying to continuously track the exact pitch.
My recommendation for your setup
If I were tuning this rover, I’d do:
  • Frequency Detector range: 400-480
  • Filter: 7-sample median
  • Servo deadband: 3 degrees
  • Update interval: 50-100 ms
  • Mic: USB condenser if possible
If you want, I can help you write a clean ARC JavaScript script that:
  • reads $detectedHz
  • applies median filtering + hysteresis
  • maps it to D0
  • and eliminates most servo jitter
Also, if you can share which Frequency Detector skill you’re using exactly and whether the servo is a standard positional servo or continuous servo, I can tailor the script more precisely.
