Virtual Robot icon Virtual Robot — Display robot image with real-time servo position readouts and basic servo management including servo deletion Try it →
Starting A Autoposition Action From A Script In A Different Action
I'm having troubls starting a AP action from a script located on a different AP frame while it's running from within the same AutoPosition control. Is this even possable?
To be clear, here's an example: Lets say I only have one AP control installed. I have two actions I've made in this AP control. Action "one" has a script attached to one of it's frames commanding Action "two" to start. Can this be done? I've tried and I can't seem to get action two to start. If it is possable maybe I'm doing somthing wrong.
No, that would be impossible. You can do a lot more with syntax programming than block programming. Syntax programming is far more versatile. Therefore you could not convert syntax to block.
