MPU6050 Accelerometer Gyro Temperature icon MPU6050 Accelerometer Gyro Temperature — Reads MPU6050 gyro, accelerometer and temperature via I2C, initializes and returns data on-demand to EZ-Script variables using ControlCommand RunOnce Try it →
Startup Troubleshooting
Windows 8, Microsoft BlueTooth stack, and the BT dongle I ordered with my EZ-B
I can connect to the EZ-B, but the bluetooth device list swiches to "Offline" within a few seconds. Attempts to connect get this error:
https://docs.google.com/file/d/0B9sLvTII-kbYVzFTYlNWQ050VXc/edit?usp=sharing
I went through the hardware diagnostics, and everything checks out. I am getting the fast blink on the blue, as expected. The BT module light goes solid briefly after connecting, then goes back to a fast blink.
I can connect to other BT devices without issue.
What is my next step?
Do you have anything connected to the ezb , also what power source are you using and are they fresh batteries? You could try uninstalling and "forgetting" the Bluetooth. Then just reboot... Plug Bluetooth in and within a few seconds it should be available to use. 90 percent of Bluetooth disconnection is a result of aftermarket bluetooth drivers , low power( browning out) or loss of signal ( too far away)
New batteries in the holder which came with the kit. I checked the voltages from the troubleshooting video. I have tried 3 different bluetooth dongles on 3 different laptops (all combinations possible) with the same result. One XP, one Windows 7, one Windows 8. All have stock Microsoft bluetooth drivers.
