Tutorial icon Tutorial — Tutorial slide plugin for ARC: create, format and embed text and images per .ezb project; navigate/update slides via ControlCommand; auto-resize images Try it →
Ah you found it on thingiverse? That's great! I was wondering who would be the first to print a JD from there. That might have been you. Really nice work on your poppy mix - I recall replying to one of your messages online. The poppy with the skull is very terminator-like!
@AdolphSmith, I've been following your work on another forum. I think you're really going to like the EZ Robot system.
South Africa
Hi . My one servo is inverted. How do i change it on JD
I believe you have the servos connected in reverse. Simply swap the two cables to the ez-b and you're good:)
South Africa
OK Its working thank you so much.
