Python Native icon Python Native — Run real CPython in ARC with full package support, camera access, ARC APIs, and bidirectional robot control. Try it →
Stepper Motor Control in ARC
Stepper Motor Control In ARC
Hi - I'm looking at using NEMA 17 stepper motors to control my robot's head rotation and possibly a four-wheel omniwheel drivetrain. I plan to control the motors from the ARC Movement Panel. How would you suggest I implement this within the ARC system?
For clarity, I haven't decided how the steppers will be connected - will they be driven through an EZB (robot controller running Synthiam firmware) or via external stepper drivers/interface connected to the PC (USB/serial)? Also, should I rely on existing Robot Skills for movement/servo control or use ARC's JavaScript/Python scripting for custom logic? Any guidance on the preferred hardware connection and whether Robot Skills or scripting are more appropriate would be helpful.
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
Control brushless motor controllers (hoverboard-style) via EZ-B: configure direction, speed and optional brake ports for DIY robot movement.
Stepper Servo by Synthian Inc.
Control up to 127 stepper motors via Arduinos mapped to ARC servos; supports any stepper driver, serial network, home calibration, speed/accel.
Yes - ARC can control stepper motors, but the best implementation depends on what you want the stepper to do:
1) For a head rotation stepper
Use the Stepper Servo robot skill.
That skill lets ARC treat a stepper like a servo using a virtual servo port (v0 to v99), which is a very clean fit for something like pan/tilt or head rotation.
With that setup, you can do things like:
Servo.setPosition(v1, 90)
or use the GUI and scripts together.
This is usually the best route if you want:
  • repeatable positioning
  • home/calibration support
  • speed/acceleration control
  • simple ARC integration
2) For a 4-wheel omniwheel drivetrain
I would not recommend using steppers directly through ARC Movement Panel unless you already have a dedicated stepper motor controller layer that handles:
  • closed-loop or open-loop stepping
  • acceleration/deceleration
  • synchronized multi-axis motion
  • homing / calibration
  • motor current handling
For drivetrain motion, ARC’s Movement Panel is best when the hardware underneath already behaves like a movement system. Steppers can be used, but they usually need a proper motor controller architecture behind them.
ARC Movement Panels are designed to abstract the robot’s motion, but the actual motor control still needs to be provided by hardware or a skill that implements that movement behavior.
Hardware connection options
Option A: External USB/Serial stepper controller
This is often the most flexible choice for NEMA 17 motors.
Use:
  • a microcontroller or dedicated stepper controller
  • connect it to ARC via USB serial
  • control it from ARC using:
This is usually the better option if you want:
  • high torque
  • proper stepper driver support
  • custom motion logic
  • multiple motors coordinated together
If you go this route, ARC scripting with JavaScript or Python can be used to send commands to the device over serial.
Option B: EZ-B / IoTiny directly
If the stepper system is already handled by a supported robot skill, this can work well.
For example:
  • Stepper Servo skill uses virtual servo ports
  • ARC then commands the stepper like a servo
  • the actual stepper driver hardware is handled by the skill/firmware layer
For IoTiny, keep in mind the port power is often unregulated on many I/O ports, so you must be careful with motor power and logic levels. NEMA 17 motors will definitely need proper external driver hardware - ARC/EZ-B should not drive them directly.
IoTiny hardware overview: https://synthiam.com/Support/Hardware/EZ-B-IoTiny
Robot Skills vs scripting
Use a Robot Skill when:
  • the behavior is already supported
  • you want UI-based configuration
  • you want the Movement Panel or servo interface to handle the motion
  • you want the easiest maintenance
Use JavaScript/Python scripting when:
  • you need custom coordination logic
  • you want to sequence multiple motors
  • you need sensor-based decisions
  • you want to translate joystick/head/drivetrain commands into custom stepper commands
Best practice
Usually the best design is:
  • Robot Skill for the hardware interface
  • JavaScript/Python for behavior and automation
That keeps ARC organized and easier to maintain.
My recommendation for your project
For the head
Use:
  • virtual servo port like v1
  • script control if needed
For the omniwheel drivetrain
Use:
  • a dedicated motor controller / microcontroller
  • connect via USB serial
  • build either:
    • a custom robot skill, or
    • a scripting layer that sends movement commands to the controller
If you want the drivetrain to participate in ARC’s Movement Panel ecosystem, then the cleanest route is to build a Movement Panel or use a skill that acts as the movement interface. ARC does support custom Movement Panel behavior.
Movement panels overview: https://synthiam.com/Support/ARC-Overview/movement-panels
If you want to build something custom
If there isn’t an existing skill for your stepper controller, Synthiam recommends building a custom robot skill:
https://synthiam.com/Support/Create-Robot-Skill/Overview
That would be the path if you want a specialized stepper drivetrain controller that integrates tightly with ARC.
Quick question
What stepper driver or controller are you planning to use?
For example:
  • DRV8825 / A4988
  • TMC driver
  • Arduino-based controller
  • USB stepper controller
  • something else
If you tell me the exact hardware, I can suggest the best ARC architecture and whether you should use:
  • Stepper Servo
  • a Movement Panel
  • JavaScript/Python
  • or a custom robot skill
