SMTP Client icon SMTP Client — Send SMTP email (text or camera images) from ARC robots via ControlCommand; configure SMTP/auth and sender; saves credentials in project. Try it →
I have 2 EZB controllers going on same. Robot, one for motors and sensors then the other for camera and programming.
Quote:
has great specs for the price and better than Raspberry Pi for having real Windows 10
Compare Apples with Apples.
Raspberry PI 2/3 has an Arm SOC Runs Windows 10 IOT version or Linux versions There is no ARC version. Power: 5V / 500ma - 750ma =2.5 - 3.75 W
  1. Asus vivostick https://www.asus.com/us/Stick-PCs/VivoStick-PC-TS10/specifications/ and you will need 9V / 2A = 18W
Don't know how small you needed to go but I just purchased one of these, although out of stock now, on sale for $149.00.
www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=6033045&SRCCODE=WEBLET03ORDER&cm_mmc=Email--WebletMain--WEBLET03ORDER-_-Deals&utm_source=EML&utm_medium=main&utm_campaign=WEBLET03ORDER&[email protected]
With a size of 1.5"x7"x7" it was perfect for what I needed.
Going to run it off a dc/dc power supply.
It doesn't show being on sale anymore but something you might look into.
The advert that I saw did not mention the 18 watts ,sounds kind of high for a little stick? The vivo I meant, will look at the other options out there too.
I made some corrections (V / A / W) Full windows, Full ARC comes with a price.
@Herr Ball
Nice price.
#15
The next robot will be a larger more sturdy All wheel drive tank design aluminum instead of plastic so a better battery system will need to be designed to handle all the extra electronics,bigger motors.
