Ultrasonic Distance icon Ultrasonic Distance — Displays HC-SR04 ultrasonic distance readings in ARC; scriptable via GetPing(), pausable, sets a variable with multiplier, optional NMS output Try it →
Is this a project that's been updated from the old JD to the new one?
If so I think you need to import the design from the new JD project. I don't know 100% since I've not done it but I remember there is a topic somewhere about this.
Try this...
Click on merge
Navigate to the Examples folder
Open Model Template JD
Choose Yes
Select EZ-Robot to import
Click OK
Voila, JD Model imported in to the project
i got the topic from dj and try it out.whit no luck.
ok i got the 3d but it keeps turning
That's because it's designed to keep turning, that's the nature of the control.
Click the design button on that control to open the designer where you can rotate the robot as you please or make adjustments.
great.rich you bin a awesome help doing all the effort to post all the pics. its outstanding perfect.i hope you get double points.
thank you thank you thank you
