RGB Animator icon RGB Animator — Create custom animations for JD Humanoid's 18 RGB Eyes LEDs via I2C - per-LED color frames, transitions, pauses, scripting and real-time preview. Try it →
Italy
Hello. I have installed 2.5 Amp Motor controller and now i am writing the code for controlling it. No problem for setting speed, but i am not able to stop pwm.
This is the code i have used for setting speed and it works fine: Private Sub button2_click EzB_Connect1.EZB.PWM.SetPWM(Digital.DigitalPortEnum.D15, 50) End Sub
This is the code i have used for setting speed faster and it works fine: Private Sub button3_click EzB_Connect1.EZB.PWM.SetPWM(Digital.DigitalPortEnum.D15, 100) End Sub
And this is the code i have used for stopping pwm and it does not works: Private Sub button1_click EzB_Connect1.EZB.PWM.StopPWM(Digital.DigitalPortEnum.D15) End Sub
Well, pressing the button, it has no effect and the motor continues tu run. Maybe i have forgot something or i have write something wrong.
Any suggestion?
Thank you.
