Inverse Kinematic Arm icon Inverse Kinematic Arm — Control robot arms with inverse and forward kinematics, converting X/Y/Z positions into joint motion and reporting end-effector location. Try it →
Netherlands
Strafing With Ar2 Drone Using ARC
Hi, I have a quick question regarding the scripting functions for an AR2 drone. Is it possible to make it strafe left or right using the EZ-script? As far as i can see you can only make it go up/down, turn left/right and move forward/reverse. With any controller you can also make it strafe so I was wondering if there is a possibility for this using the EZ-script.
The term used for drones is roll. The command is rollleft() or rollright()
You will find all drone commands in the script manual by searching for the word drone. There is also takeoff and land, etc.
Netherlands
Thanks! I looked over it
