XV11 LIDAR icon XV11 LIDAR — Real-time 2D mapping from Neato XV-11 360° LIDAR via GetSurreal controller; exports $LIDARDistance/$LIDARIntensity, configurable angles, color, zoom. Try it →
Hello Everyone,
I'm in the middle of my robot build ,and I need to calibrate the servos.I have two laptops. One has bluetooth, the other one doesn't. They both have the EZ download in them. When I go into the examples box to calibrate the servos, the computer without the bluetooth has the correct drop down box, and I see the servo calibration. When I try to use the other computer the example box isn't the same, and I can't find what I need. Instead I get the words " example, functions, and robots".
When I click on those I get other words like servos etc. I click on that and on the right I get some kind of configuration.
How do I get the coeerct box?
Thanks, Den
Hi!:)
The tutorial page for calibrating servos can be found here: https://synthiam.com/Tutorials/Default.aspx?id=8
The instructions read....
Quote:
9) Select and load the Calibrate Example Project (Examples -> Robots -> EZ BoxBot -> servo Calibration)
When you load ARC, it will tell you there is a new version. The window will flash to get your attention. It sounds as if you have two seperate versions of ARC installed:)
