Sudo's Guide To Dynamixels
PLEASE NOTE: THIS GUIDE IS OUTDATED. BADLY. (remind me later to fix this and spiff it up a bit, please)
So, you finally have your EZ-B v4. You love it already, and you're ready to hook this baby up to some sort of Dynamixel powered creation. You go to plug everything in, and - wait. You have no idea how to set those Dynamixels up.
Well, I do, and I'll show you how.
SECTION 1: GETTING TO KNOW DYNAMIXELS
Dynamixels are intelligent servos that can track not only position, but temperature, speed, and load. The servo can automagically shut itself of incase of a failure. These servos are also incredibly strong. But there's one feature in particular that is useful, but at the same time a little hard to wrap your head around. In this section, we will cover daisy chaining and other features of the AX-12A Dynamixel; however, most of the servos in the Dynamixel family work exactly alike, so this guide can help you with most models.
On the back of all of your Dynamixels, you will notice a couple things. A place for a bolt, a light, two wire ports, and the ID. Lets go over all of them so you know what they do:
Light - Blinks once when turning on. If the light is flashing, there is a failure of some sort.
Screw hole - Allows you to attach the Dynamixel to a bracket.
Wire ports - Allows you to connect to other Dynamixels, in a long strand of servos, both to and from other Dynamixels. This means both ports work the same way, which means it doesn't matter which side is plugged in. (see image below)
ID - What the EZ-B and ARC address the Dynamixel as.
PART 2: CONNECTING YOUR DYNAMIXELS TO THE EZ-B
All Dynamixels must plug into port D5 in order to properly work. This means that all of your Dynamixels must plug into one port. If you have more than one strand of connectable Dynamixels, you will have to use a Dynamixel splitter hub, like this one here:
You can either run a cable to the EZ-B via a power base or via the powered splitter. I advise that you use only one, as using both at once can brown out the EZ-B.
Q: So, now that that's done, what power supply do I use? Mains or a battery pack?
A: Both will work just fine. Just make sure you have an adequate power supply at around 10v.
"But wait!" you scream. "Dynamixels can run at 9v-12v! Why 10v?"
Because voltage is gradually lost over time depending on how many servos you're running at once, as well as when the EZ-B is powered on. The more servos you have, the higher you should up your voltage to get a steady 10v overall.
So, if you have power running to the EZ-B, Dynamixels set up to port D5 (as well as the optional splitter) you should have something resembling this:
Now that you're powered on, lets move into ARC and get your Dynamixels running.
PART 3: OPERATING THE DYNAMIXELS WITH ARC
Connect to your EZ-B as usual (We won't be covering connections in this guide). Bring up a servo control panel and go to the servo configuration screen as shown below.
Click the Dynamixel box and scroll down until you see the ID of the Dynamixel you want to move (the ID on the back of the servo). In this demonstration, we'll be selecting Dynamixel AX18.
Select it and save the configuration. Congrats, you just set up your first Dynamixel in ARC! It should operate just like a normal servo. This applies to all servo control functions.
PART 4 (EXTRA): ASSIGNING A NEW ID TO BLANK SERVOS
When you buy a Dynamixel that doesn't come in the kit, the ID sticker will sometimes be blank, which means it hasn't be assigned a "real" ID. However, a tool in ARC can give Dynamixels a new ID.
First, open up the Dynamixel Config. control in ARC. You should see something similar to this:
All blank servos are assigned ID 1. If you have a dynamixel with the ID 1 already, remove it before you proceed. Simply choose the new ID you want (in this case, AX18) and press execute. ARC will assign it a new ID. That's it, you're done! You can also write the ID on the blank tag if so desired.
GUIDE LAST UPDATED: 12/9/2014
#49
That's correct, DJ has used the table entry that is used to control the maximum torque on the AX12 . So if you are running the servo on your bench it looks like your controlling the speed but put any kind of load on it and it will stop working. See my earler post on the issue. DJ's response was that it exposed a serious issue with the variable manager. I believe it is also causing the issue with the UART.
#50
I was hoping that the issue would have been resolved by now. You really can't take full advantage of the AX12 features using the EZ B until it is.
#51
@mtiberia
remember, a week in EZ-Robot time is one month in normal time;)
#52
Ha ha
Did you get to try out the script?
#53
@mtiberia
i can't right now, but i'll be sure to later:D
#54
At one point, I had my AX12a Dynamixels working, but I went to reconnect them today and ran into this issue (I think). I'm able to move any of the Dynamixels for a very brief amount of time and suddenly it seems all communication attempts fail with all the dynamixels.
I've run the reset return script multiple times, but with no luck. Does my issue sound like it's caused by the issue this thread is mentioning?
#55
If you're using ARC just set the speed to 100. I'm away right now and don't have access to the code for reference.
#56
mtiberia,
Using Sudo's instructions, I have connected the 16 AX-12A's on my Robotis Premium robot to the EZ-B4. I was able to map all the servo's, set their initial positions, and actuate them from the EZ-B4. I couldn't set poses or get get the walking positions working very well.
I tried your AX12ControlEZB-635552623864353750.ezb to see if I could understand more about how the EZ-B/AX-12A interface worked. I tried 'resetting return level' and 'Reading Position of Servo'. They ran without errors but didn't provide the insight I was looking for.
I decided to go back to using the Robotis CM-530 to control the servos and connect the EZ-B4 to it thru the "Communications Jack" ( a 57600bd UART). Much to my dismay - The RoboRoboPlus Manager reports all AX12 IDs as "UNKNOWN" and my CM-530 does not control the servos.
Any Idea what I can do to restore the RoboPlusManager's reading of the AX-12's ID? EZ-B4 reads them OK.
