Robotis Openmanipulatorx icon Robotis Openmanipulatorx — Inverse kinematics for Robotis OpenManipulatorX: compute joint angles and MoveTo 3D (cm) positions, supports camera-to-CM mapping for pick-and-place. Try it →
Suitable mini PC to support ARC software
Suitable Mini PC To Support ARC Software
What mini PC would you recommend to use with ARC for a robot? I have been reading about Kangaroo mini PC, LattePanda, Raspberry PI, MeLE PCG35 GLK. I like the Kangaroo PC but everything I read abut it is 5 years old.
My 3D printer is a Flashforge Guider IIs.
hi afcorson
can you give us some messurments please ?
hi afcorson
did you print the hands with the fingers in one piece ?  or separt .cause the stl is with fingers included.
thank you
As mentioned in my comment on Feb 17, the fingers are cut-down InMoov fingers.
#39   — Edited
You can split STL into separate parts (sometimes) using the freeware PrusaSlicer 2.3.3. Using this software, you can remove the fingers from the hands, separate the eyes from the head, etc.
hi afcorson
thanks for the info . i did remove the fingers in TC .
