Key Control icon Key Control — Assign scripts to any keyboard key (press/release), map arrow keys to movement controls; activates when the control has focus (green). Try it →
I believe waterfall relates to the gopro camera and software. Have you had gopro software installed on your computer then uninstalleld it? If so, reinstall it and try again. From what I've heard, uninstalleld gopro software also removes files it shouldn't and a reinstall puts them back.
I uninstalled gopro restarted and the error message is still the same: No DLLs ware found in the waterfall procedure Now I still have a doubt I also uninstall avast?
Uninstalling the gopro software does not remove the offending dll's, you need to manually delete them. See the thread I linked to.
Ok no longer appears the error message and managed to collegre the cam, thanks for help, are not ruscito to link a photo to the forum posts I can explain step by step how I do thanks and greetings from Italy Roberto
