Dialogflow icon Dialogflow — Add Google DialogFlow NLP to ARC: conversational intents, parameter prompts, scripted responses, service-account setup and programmatic robot control. Try it →
To control a DC motor you need an H-bridge motor controller. They can all switch direction, most can control 2 motors. Start with how many amps your motor draws at stall, and we can advise on what controller you need.
Thanx Alan. I have an H bridge for the drive motors , I only have a small dc motor that only needs to move lest to right, not 360.
Still needs an H-bridge. EZ-B (or any microcontroller) drive servos natively because servos have little h-bridge contoller boards built in. To drive a motor, you need a motor controller (could do it with a relay, but then no polarity or speed control).
If you only want to go left or right a specific distance and not continue rotating, then replacing the motor with a servo is probably your best bet since it also has the potentiometer and feedback circuit to read position built in. Recreating that for an existing motor will cost far more than just buying a servo.
Hmmm, maybe I should switch to a servo
Ok, 5Volt,,, one small DC Motor , is there any H-Bridges that only control one small motor?
eBay will be your best friend. I don't know of any.
Of Course I can use a dual H-Bridge and use the second connection for something else?
Yup. Note, with an H-bridge, it isn't the volts, it is the amps that matter. A small 5v hobby motor is probably fine with a cheap 2amp H-bridge, but if you have the specs of the motor, you should check.
