Midi Control icon Midi Control — MIDI I/O for ARC: send/receive notes, run per-note scripts, control PC or external instruments, with panic to stop stuck notes. Try it →
Not with ARC. You could use the custom haar (I think could be harr or even haas...) detection but it is limited to one item and not well documented.
That's unfortunate. Can you recommend another software that can allow me to do this?
You could use the SDK
Wouldn't this be similar to glyph recognition? I've not messed with it yet but there are some predefined glyphs you could use. You could also use RQ codes as well. Unless it has to be a heart. It may not be exactly what you're looking for but if you're not married to hearts you may want to try those options out in ARC.
Wolf King, use Open CV - Computer Vision Library
Open CV is compatible with ARC, but limited to one item.
There is a freeware program to create your own "glyphs" ...the more ways to communicate with your robot the better....and the advantage of glyphs over VR is anyone can communicate with your robot!..thanks for the tip @Rich
@irobot58 I have only looked at the glyph feature so I'm sorry if this is a dumb question: Can you import a glyph into that function? I have plans on messing with it soon and I just was wondering if that's an option. BTW could you post a link to that freeware? I'd like to check it out. Thanks
