Soundboard (PC) icon Soundboard (PC) — Play and manage MP3/WAV sound effects from a PC soundboard, load tracks, trigger or script playback (one file at a time), export and automate. Try it →
Syntax Error In Ez Script. I Am Missing Something
Hey guys. I am just starting to write a script for my bot and I am trying to get data from a Parallax ping sensor and decide what to do with the data.
I think I have typed the script right but I am getting an error. Can you guys take a look and let me know where I messed up.
Thank you
Did you want to state the same port twice? Here is what you have: (D8,D8). Then in the next statement you have (d8,D8). I don't knew how the Ping thing works as I haven't worked with my Sonar yet but listing the same port seems odd to me.
I just copied your script and tried it and got the same issue. I then got rid of one of those D8's and it ran without error.
Again, I don't know if you have your sonar attached to two ports that need monitoring. Let me know what you find as I'll be using this in my build sometime soon.
Here's a navigation example written by DJ that looks like the same thing your doing.
# This variable will be used to determine if we exit.
# If it is a 0, we continue running
# If it is a 1, we exit this script
$exit = 0
# begin moving forward
Forward()
:Start
  # Get the ping sensor value
  $ping1 = GetPing(d9, d8)
  # If the ping sensor value is less
  # than 20, alarm!
  if ($ping1 < 20)
    goto(Alarm)
  # If the exit value is 1, exit the script
  if ($exit = 1)
    goto(Exit)
  Sleep(500)
Goto(Start)
:Alarm
  Stop()
  Say("Object Detected")
  left(255, )
  Sleep(500)
  Forward()
Return()
:Exit
  Stop()
  Say("Received Command Stop")
Halt()
Looks like you need to specify a value for the GetPing in this script.
Hi Dave.
I was just going by the example in the script helper for the GetPing. It says you need the trigger port and echo port. Since I am using a Parallax ping it only has 3 pins versus the one that comes with the kit it has 4.
The reason I like the Parallax ping is it saves on D ports.
Oh I see what you talking about I use the getping to get the data and put it in a variable then use the variable in the logic.
I'll try that when I get a chance.
Thanks for the help Dave.
I don't understand why the statement works on DJ's example and not yours. Perhaps you need to write the script using variables like DJ has done.
I wrote my first movement script trying to use numbers just like you did instead of a started variable and is would not work. Once I redid it all worked nicely. See my "Move Waist" script in B9 Robot Control in the EZ-Cloud.
Well you have given me some great ideas to try so really thanks for the help
I edited my post above and you may have missed it.
