Kondo KRS ICS Servos icon Kondo KRS ICS Servos — Control Kondo KRS ICS2/3.5 servos via EZ-B UART; experimental, untested. Supports chaining, virtual servo ports, Release() and Servo() commands. Try it →
TCP Clients dropping Python connection
TCP Clients Dropping Python Connection
I’ve got an OpenCR 1.0 (Robotis) on USB COM5 running DJ’s EZB-compatible firmware flashed via Arduino IDE. In ARC on Windows, Connection 0 is set to 921600 and talking fine to the board (I can move a standard RC servo on a PWM pin and read an analog input reliably). I enabled "TCP Server" in the Connection’s Config and added the TCP Clients skill to monitor connections because I want to poke ARC from a Raspberry Pi over the LAN.
Here’s the odd bit: a simple Python socket connect from the Pi shows up in TCP Clients for a second or two, then drops unless I constantly send bytes. Even with a basic keepalive, it still drops intermittently whenever ARC is busy driving the OpenCR (e.g., moving servos). Minimal test:
import socket, time
s = socket.create_connection(("192.168.0.42", 6666))
while True:
    time.sleep(3)
    s.send(b"\n")  # keepalive
  • I can reproduce this from another Windows laptop too, so it’s not just the Pi.
  • Windows firewall is allowed, and I tried a different port.
  • If I spam bytes every 200 ms, it tends to stay connected longer, but it still sometimes drops exactly when high serial traffic goes to the OpenCR.
Is the Connection’s TCP Server meant strictly for EZ-B binary protocol pass-through (and thus closing idle/non-protocol clients), and if so is there a recommended keepalive/handshake pattern or example for a Python client to maintain a stable connection while ARC is driving an OpenCR at 921600 over USB?
Opencr by Robotis
Turn OpenCR into an EZB controller for ARCx: drive Dynamixel servos, PWM, sensors, UART and scripts at 921,600 baud.
USB
Servos 200
ADC ✕
Digital ✕
Serial Terminal by Synthiam
PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hex
Yes - what you’re seeing is consistent with ARC’s TCP Server in Connections being for ARC/EZ-B protocol clients, not a general-purpose "any TCP client stays connected forever" server.
When ARC is busy talking to an OpenCR over USB at 921600, the connection manager can become more sensitive to clients that:
  • connect but don’t complete the expected protocol exchange,
  • stay idle too long,
  • or send bytes that ARC doesn’t interpret as valid traffic.
What this means
If your Python script is just doing:
and then sending \n as a keepalive, that usually isn’t enough unless the client is speaking the expected ARC/EZ-B communication pattern.
1) Treat the TCP Server as protocol-oriented
Use it for one of these cases:
  • a real ARC-compatible client
  • a custom client that implements the EZ-B protocol
  • a bridge service that you write in Python to translate your own messages into ARC-compatible commands
If you want a custom client to remain connected reliably, it should send a valid initial handshake, not just arbitrary keepalives.
2) Use a proper protocol handshake
For ARC/EZ-B style connections, the controller expects a startup exchange. From the protocol docs:
  • connect to the TCP endpoint
  • send the required initial byte / handshake
  • then maintain the session with valid traffic
The protocol documentation is here:
That page describes the controller communication model ARC expects.
3) If you only need LAN control, use ARC as the command processor
A good pattern is:
  • Raspberry Pi sends simple app-specific commands to a small Python relay you control
  • that Python relay then sends valid ARC/EZ-B commands into ARC or directly to the controller as appropriate
That gives you a much more stable architecture than trying to keep an arbitrary socket alive inside ARC’s TCP client list.
Why it drops when servos move
When ARC is actively driving servos, ARC is also:
  • polling/streaming commands to the USB controller,
  • servicing the control loop,
  • and handling the TCP subsystem.
A non-protocol TCP client that is "just there" can get disconnected if ARC decides the socket is inactive or not participating in the expected command flow.
Better options for Python + ARC
If you want to drive the robot from Python, I’d recommend one of these:
Option A: Use ARC’s built-in scripting / commands
Have Python talk to a tiny local web service or socket server you create, and that service triggers ARC robot skills or scripts.
Option B: Write a custom ARC robot skill
If you want a clean, supported interface in ARC, create a custom skill that exposes exactly the behavior you want.
Guide:
Option C: Implement the EZ-B protocol directly
If your goal is to make the Raspberry Pi a real client of the ARC-style connection, then your Python needs to speak the protocol, not just keep the socket open.
Practical next step
If you want, I can help you build one of these two:
  1. A Python example that properly connects and keeps a TCP session alive in the way ARC expects, or
  2. A small ARC skill / script bridge so your Pi can send simple commands reliably.
If you choose the Python route, tell me:
  • which TCP port ARC is listening on,
  • whether you want to control servos, digital pins, or movement,
  • and whether your Pi should talk to ARC or directly to the OpenCR.
