Joystick (Xinput) icon Joystick (Xinput) — XInput joystick skill for ARC: maps Xbox controllers to movement, servos, triggers, vibration, variables; supports analog inputs and scripts. Try it →
Talking Servo / Inmoov Mouth Closed After Sentence
Hello,
i have a problem with my inmoov.
I add a "talking servo" i adjust the servo - everything is fine i have only one problem:
After a sentence the inmoov leave is mouth open. Nevermind how long or short the sentence is... the mouth is in the end still open.
I cant find any option to say after a sentence got to this servo postion.
Thanx for help.
Boris
#17
@renta can you share your configuration screenshot? Just like bhouston had done?
I wonder if your MIN is greater than your MAX
#18
@DJ no prob here is the pic!
@bhouston no this servo has only one job, talking servo. no use in other script or else.
HI DJ,
do you found something what can be wrong?
Boris
#20
Not sure Boris... Talk servo works perfectly for me, even without periods at the end of sentences....
#21
Boris, give me an example of a phrase that causes the issue.
#22
Hello DJ, Hello Richard, Hello Bhouston,
so i made a video where you can see on this simple phrase
"Hello DJ - Mein Name ist Sigi"
how the mouth works - and that the mouth is still open in the end.
I try also with a closed mouth from the start - to say samoething - No change in the end still open.
Boris
#23
I just replicated your problem, Hopefully, I can explain how to fix it. I think the key is to determine the open and closed positions of the jaw first. With the sliders in the "Talk Servo" control, set the jaw to the open and closed positions. I my case 70 is open, 95 is closed. Then run it and see what you get. I had to then Invert the direction.
#24
Hello Bob,
i set the open and close position in the settings of the Talk Servo.
So "180" is ful closed postion and "155" is good open position.
Else i don't understand what i must change.
And like you see in my video the invert have no function!
One info --- i connect only the "S" cable from the servo to the EZB4. The Voltage comes directly from a power supply - not from the EZB4.
Boris
