SSC-32 Servo Controller icon SSC-32 Servo Controller — ARC integration for SSC-32 servo controllers via PC COM or EZ-B/Arduino UART; maps V0-V31, configurable baud, enables servos in ARC skills. Try it →
Team Viewer
I have my telepresence robot Tellie which I want to control securely off site.
This is what I don't know. I am using TeamViewer connection to allow my grandchildren to take control of my computer and control Tellie. Tellie is a telepresence Create 2 controlled by Ezb. I want them to be able to control Movement Panel and Dock command on my my computer with an apple iphone. TeamViewer will allow me to control my pc at home with a Iphone at their home. I can do that by letting them control the my computer screen running Ezb. The problem is I don't know if they will be able to use the Ezb control control panel because of the size of the Ezb screen on the iphone.
Is there any way to make a mobile control that works on the same pc that the ezb software is running. Then all they will see is the mobile control when the connect to my computer.
If this is impossible how can I make the movement control larger.
This is good Alan and Frank. So I can use yours Frank or create an interface panel in mobile interface builder on my second screen and either one will work on my pc for a cleaner interface.
This is the information I needed. Thanks to both of you.
Ellis
Hi @Ellis, Here is a pic of my personal Mobile Interface running on a laptop that is being connected to via Splashtop (similar to Team Viewer)
The screen shot is from an iPhone 7 Plus and the controls/camera are of a usable size
I think this will approach will work well for your grandkids
Regards, Frank
Remember you can change the font size on those controls to make them much larger and easier to read.
This is great Frank. The font recommendation is a great idea.
Thanks Ellis
