Vertical Servo icon Vertical Servo — Drag vertically to control a servo within set min/max limits; center, release, invert, and mirror to other servos. For 3-wire GVS servos. Try it →
Nice, that base is awesome to work with. I have used it on a couple of my projects.
I'm a fan of rad. It's even better if you ditch the gearbox and install high torque motors because the original plastic gearbox is a noisy one.
Any tips on switching out the gearboxes with servos? I finally got to hacking my RAD and one of bthe gear boxes seems faulty:(
@RR333 , servos are brutally slow in comparison to the original motors but if you are ok with that then you could glue the large gear to a servo modified for continous rotation. Take in mind you will want to use a high torque servo for this job because a standard servo will not have enough torque to move a base the size of a RAD around. A pollolu.com power hd 1501mg (240 oz in 6v ) should do the job as long as you stay on smooth surfaces but not outdoors.
Thanx; I opened up the faulty gear box and it was just the gear on he motor shaft came off, I put I back together and it works, then popped off again. Should I superglue it on? If I change the motor out with a High gear DC Motors later It may be hard to get the gear back off again:( What's worked for you? also does that engine sound dampening stuff work well you guys are putting on he gearboxes? thanx again.
