Translate icon Translate — Translate text via Microsoft Translator (auto-detect); EZ-B plugin stores translated and detected language variables. Requires Azure key. Try it →
Resolved Resolved by Antron007!
The Mobile App Freezes Up In A Please Wait Screen After An Apparent Bluetooth Co
I am using the app for the first time. I have a V3 board on my robot. No other Bluetooth devices are active.
My phone sees EZ-Robot Bluetooth and successfully pairs with it.
When I download my project from the cloud, tap the Connect window, select EZ-Robot Bluetooth on the WiFi/Bluetooth screen that appears, and tap the Connect button on that screen, the red LED on the V3 board stops blinking, indicating successful connection. But the phone screen freezes up on a "Please Wait" screen. If I try to get back to my project screen I get a message saying "EZ-Builder isn't responding. Do you want to close it?" The only choices are Wait and OK.
Any suggestions?
By the sounds it could your device overloading. I could be wrong. Let these guys check the file to see.
To: Antron007
Thanks for a very good response. I carefully did everything you said, but the result is the same. My available RAM with everything reasonable to delete is 131MB.
To: All
I used a very simple test project: only a Modified servo Movement Panel. It's on the Cloud as "Simple Mobile App Test" in my "dicka" folder.
What happened when you run the simple test project? I presume you did run it? You didn't say if you did or not hence the question.
Posting a different project really wont help us since the simple project you posted should work on any android device capable of running ARC Mobile. If even that app doesn't work for you then your android device isn't up to the job of running ARC Mobile (it should run on any android device capable of running ARC - if it doesn't then I doubt any other app will run). If it does then we really need to see the project that is causing you problems otherwise it's like taking a different car to the garage to be fixed...
dicka,
My idea is for you to try it on another phone. If it works on another phone, you have solved your issue. Steve S
Yoir simple mobile app opens fine on my HTC One M8.
Same on my Samsung Galaxy Tab 3... opens no problem...
#15
Just to be clear, opened and connected to my EZ-B v3. Did not lock up.
#16
It shouldn't lock up on any device capable of running ARC Android, it's a very simple project. If it does lock up then the device used isn't capable of running any ARC app and the solution would be to use a more powerful Android device.
The Acer B7 is a cheap android tablet which is capable of running everything I have thrown at it so far. The older Nexus 7 has dropped in price too. That's just 2 which are more than capable.
