MPU6050 Accelerometer Gyro Temperature icon MPU6050 Accelerometer Gyro Temperature — Reads MPU6050 gyro, accelerometer and temperature via I2C, initializes and returns data on-demand to EZ-Script variables using ControlCommand RunOnce Try it →
The Speech is cut off using Bing Speech and CHATGPT and IoTiny
The Speech Is Cut Off Using Bing Speech And CHATGPT And Iotiny
So I ask the BingSpeech "What is your name?" it sends question to CHATGPT which then provides it response in the form of the $OpenAIResponse "My name is XR1..........." but what I get out of the speaker is "is XR1......" or "name is XR1........" Why would it be cut off like that?
@Nink I have not tried Watson speech to text and text to speech skills for this.  I just can't understand how it can be dropping part of the output in the audio.  The EZBSAY command is sending the complete response but parts are missing in the audio output. To me this sounds like a software issue talking to the hardware or a firmware issue in the hardware. I know wifi can cause delays but if the packets got sent and received the audio should play everything not parts of it.
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
ChatGPT chatbot for robots with memory, image description, personality scripting, and voice conversation via OpenAI API
#9   — Edited
It has nothing to do with Bing speech recognition. Id guess your code is looping and trying to execute something in repeat when trying to speak. Or trying to speak immediately after another speak.
or you changed the settings in the iotiny configuration. And should reset
or your network is too slow and it’s cutting off
or your ARC preferences have been changed and the default should be restored
DJ,  yes other skills are in the project the code to speak is one line command per your instructions in the CHATGPT skill setup. It was my understanding that ARC was a multi threaded application.  In this instance the camera skill was operating off a EZB4, 3 servos and a speaker are connected IoTiny the servos were holding position but not moving. Nothing else is running.   I have know clue of what settings you are talking about in the iotiny.  it is not the network.   I have not changed my preferences in ARC as this was a fresh install but I will look for a place to reset them to default.
#11   — Edited
ARC is a multi threaded application and takes advantage of Windows ability to do so. If I understand what you are saying, you have one script calling the same event to different devices? You may need to have the script pause a bit and let the command execute before it calls the event again.
@Dave,  No that is not what I am saying.  ARC uses skills within a project.  So each skill is its own background process that talks to the core application which is kind of acting like a traffic cop sending information to hardware and other skills.  So in this case Bingspeech takes input from the mic translates it to text,  then sends this text through ARC core engine to the ChatGPT skill then this skill sends this information to OpenAI services which in turn sends the reply back to ChatGPT then the ChatGPT skill has a one line script that calls Audio.sayEZB($OpenAI Response) that goes through the ARC core engine and send to the IoTiny hardware through a WiFi connection.
Yes there are other skills the ARC core engine is dealing with as part of it normal design and operation.  No other skill is trying to use the speaker other than ChatGPT making that call. No other INPUT's are being sent to BingSpeech or ChatGPT when this happens.  If this was a network issue it should not only happen at the start of the Audio output.   This in my opinion is not a network issue. it is also not a computer issue as I have tested this running ARC on more than capable PC's.  It is not a power problem to the IoTiny.  If anything it seems like the hardware can't process the audio input fast enough, but I would find that hard to believe.
@smiller29. OK I understand. I really don't have much more to suggest. I've never used ChatGPT. Sounds like there is a lot of back ang forth going on. It still sounds like a process is taking a bit longer to finish and cutting off your final returned audio output.
However, have you tried to open a new, clean ARC project and "only" add the speech and chat skills you're using? Then only send one command through the system at a time? Take everything else out of the equation.
Or
Use an EZB instead of a Iotiny? Can you hard wire the EZB to the computer through USB? I know you want the little Iotiny and a wireless connection but this would be for troubleshooting.
Twitter
I agree it is not a network issue. If Athena is correct ARC is creating the WAV file and transmitting it to IOTiny.  Since it is TCP the entire file is sent.  If it was streamed using UDP I would suggest network issue.
#15
@Dave, I can try that Dave but what is that going to do for me? If it works my project needs more than just these skills so I don’t know how this helps me out.
#16
There could be a few reasons why this is happening. One possibility is that there might be a limitation or configuration setting within the BingSpeech or text-to-speech system that truncates or cuts off longer responses. This could be due to the maximum length of the audio output or other constraints.
Another potential reason could be related to the way the integration between BingSpeech and CHATGPT is implemented. It's possible that the text generated by CHATGPT is not being passed correctly or completely to the text-to-speech system, resulting in the incomplete pronunciation of the response.
