SMTP Client icon SMTP Client — Send SMTP email (text or camera images) from ARC robots via ControlCommand; configure SMTP/auth and sender; saves credentials in project. Try it →
Thermal camera AMG 8833 connection and overlay
Thermal Camera AMG 8833 Connection And Overlay
Hi DJ Sir,
First of all thank you very much for creating such a wonderful software called ARC which made my dream robot come true, but at present i got stuck with the thermal camera. I request you to guide me how to connect AMG8833 with openCM 9.04 and overly the image using ARC?
Waiting your advice.
Warm Regards, Kishore Rao.
Opencm 9.04 by Robotis
OpenCM 9.04 with Synthiam ARCx drives Dynamixel servos in a web browser for animations, scripts, AI and hardware I/O
USB
Servos 200
ADC ✕
Digital ✕
Camera Overlay by Synthiam
Displays trained object names as overlays on the Camera Device video stream using Camera Device's object-tracking (shows $CameraObjectName).
Hello @Electrofurb.
To connect the AMG8833 to the OpenCM you would need to use I2C (likely with level shifting).
There is an Arduino library by Sparkfun that should help you with the communication but it will merely give you empirical data.
In order to get visual color image you would likely have to build your own skill control or try to get the USB version from Digikey and try to incorporate their software in some way.
The only other idea I can think of is using the empirical data with the E-19 RGB 8x8 display but you would have to make the E-19 first. The E-19 is 64 pixels which is the same resolution as the Grid Eye. Looks like Sparkfun has done it in the past.
Interesting sensor. I2c is pretty slow but it can work.
so the arduino you’re using is the robotis opencm... hmm, I don’t think i2c is implemented in the ezb firmware.
i can add support for I2c. But then you’d need someway to view the data. Using I2c read commands, you can easily store the data in an array to access via code. But sounds like you’d like to visually see the 64x64 image? If so, a skill control would be created.
I can help with that, but I’d first like to know what you would use the sensor for? Do you have an idea of what the sensor would be used for on your robot? That’ll help me understand the skill control features
#3   — Edited
Hey DJ,
We have an AMG8833 eval board in the lab if you want me to send you one.
It's an 8 x 8 image (64 pixels total) which matches perfectly to 8 x 8 RGB matrix displays.
I’ll take a look when I’m back. Sure we can come up with something interesting with it
Hi DJ Sir, I am really glad to see your swift reply. As you mentioned above, yes I want to connect the AMG8833 and view the 64x64 image (like how we view the image through camera control along with the overlay) and the robot will display the warning if the temperature is above the desired level. Actually I am developing a robotic device which scans the PCB and identify the electronic component which is getting overheated. Please don’t worry about the resolution, just a rough overly with temperature reading will do. Hope you will help me to complete my project. I also like to Thank Jeremie Sir for the feedback. With warm regards, Kishore Rao.
#6   — Edited
This is the sensor which i want to incorporate in my project.
#7   — Edited
Hi DJ Sir,
Hope you are doing well. I am waiting for your guidance. I understand you are very busy with your schedule, sorry to bother you.
