Bing Speech Recognition icon Bing Speech Recognition — Accurate Bing cloud speech-to-text for ARC: wake-word, programmable control, $BingSpeech output, Windows language support, headset compatible Try it →
#161
Hi Alan How do you get to where you can change the WIfi Channel. Its working fine with me turning off the wireless cable unit but wondered from what you said would a different channel allow me to leave it turned on. At least I know JD is not a defect NO jamming works great! Also my windows 8.1 is asking me to upgrade to 10. Will this screw up any of the JD stuff I did already? Is 10 much better? Thanks Ron
#162
Turn JD on and connect to it's Wifi, then open your web browser and go to https://192.168.1.1 which will open the EZ-B's web page.
Click on the Wifi AP Mode button on the left, and the second item on the page that opens is the WiFi channel. It defaults to channel 1, which is also the default for almost every Wifi device out there. Try 6 or 11 (you want to go at least 5 channels up from the busy one for full frequency separation).
A few people have had issues with ARC upgrades after doing a Windows 10 upgrade. I had no issues, but to be safe you can save your JD project to the cloud and uninstall ARC first if you want. I have windows 10 on four machines, and the two that were Windows 8.1 both have far fewer WiFi problems (and fewer problems in general) than they did previously. The third machine started as Windows 7 and never had WiFi problems, but it works better on Windows 10 in all ways - boot faster, runs faster, less problems in general, and it is a really old slow machine. I was surprised it was up-gradable. (the fourth I got with Windows 10 already installed). However, @Oldbotbuilder had WiFi problems after upgrading from Windows 7 to Windows 10, so your mileage may vary.
Windows 10 is much better and no, it won't break what you have done.
You change the radio channel on your access point if you are using client mode, and on the ezb if you are using AP mode. It is normally labeled Channel on the Web page used to manage your access point or router.
#164
Everyone Thanks for that help. I guess I should think about the upgrade. Maybe because I don't have much of this computer now would be the time to upgrade. If I change the channel of wifi does that change anything with my Router DSL for online? Thanks Ron
#165
No, it won't impact your dsl. I would go ahead with the Windows 10 upgrade sooner rather than later. It will only be free for a year, and probably easier to learn before you get too used to windows 8.1. Not too many differences, but a few.
Don't worry about the uninstall /re-install of ARC. DJ just fixed the issue in today's release.
#166
Will try and see if it offers me to update today and than I'll do it. Later boys Ron
#168
Thanks Richard From the past I try to let the computer offer the update rather than me getting the wrong thing. I did go to get it as you said but it says system down now, so I'll try later. I updated DJ's newest ARC and to wait for 10. TRIED to update to 10 5 times won't let me do it. says system is down. HELP! Thanks Later!
