Brushless Motor Movement Panel icon Brushless Motor Movement Panel — Control brushless motor controllers (hoverboard-style) via EZ-B: configure direction, speed and optional brake ports for DIY robot movement. Try it →
Portugal
Three Function Gripper
Hello everyone!
I am an engineering student and I am currently making a robotics project that consists in building a three function gripper to be used in a robotic arm. I was given a few specifications that are quite different from each other. Basically I have to build a gripper that: Lifts 25Kg palets with 1200800140mm Lifts 30Kg cardboard boxes with 600800500mm Lifts a cardboard pallet pad that weighs 1Kg.
I was thinking of creating a vacuum gripper with 2 jaws and I would use the vacuum for the pallet pad and the jaws for the rest. What do you do think of my solution?
Thanks :):)
