I have a three wire Ping sensor. Can I use it with my EZBv4? I have used the normal 4 wire sensor from EZ robot but would like to use the other sensor I have available.
Thanks to All Ron
Single Camera Servo Server
— TCP video server for Unity clients to stream camera video and send servo positions to ARC for remote robot control
Thanks to All Ron
Yes... you will use the same port for both trigger and echo..... don't forget to use a 5V regulator with it...
Thanks Richard, I had a feeling you might have the answer for me. I will be using it with two 4 wire sensors for avoidance, a total of 3 sensors. I assume I program it the same as the 4 wire? Ron
yep, everything should be the same....
