Tip120 & Tip122 Transistor Switching Circuit
I just decided to redo one of my TIP122 Transistor Switching Circuits (mainly because I needed a break from working - there is nothing wrong with the 2 that are already in my Hearoid). So now's as good a time as any to do a small tutorial:)
This has become an evolving tutorial with additional information and options available being added. The change log at the end of this post explains changes made. Any additional information will be added as and when discovered.
Parts needed: 1 x TIP120 or TIP122 Darlington Transistor or IRL3103PBF Mosfet (see notes at the end) 1 x 1k ohm Resistor 1 x Small Piece of Strip Board (7x5 holes) 1 x Pin Header (1x2) 1 x servo Extension Solder Soldering Iron Cutters
Extra parts needed (if inductive load): 1 x 1n400x Diode as required
Search for part numbers in google or ebay or use your preferred supplier.
The Schematic:
Underside of Board:
The optional connections are for Diode D1 covered at the end of this post.
Method:
  1. Solder the TIP transistor to the strip board so each pin is on a separate strip of copper
  2. Solder the resistor from the Base of the transistor to a spare copper strip
  3. Cut off the end of a servo Extension and strip back the wires
  4. Solder the Black wire of the servo Extension to the strip connected to the Emitter of the transistor
  5. Solder the White wire of the servo Extension to the strip connected to the end of the resistor (not the transistor end)
  6. Solder the Red wire to a spare copper strip
  1. Use a small off cut from the servo Extension and solder one end to the strip of the Collector of the transistor
  2. Solder the other end of the off cut to a spare copper strip next to the Red wire.
  3. Solder the Pin Header to the copper strips with the red and black wires soldered
  4. Job done. Plug the servo Extension in to a Digital port on the EZB and connect the circuit that needs switching to the Pin Header, I do this with another servo Extension (as I have hundreds of them)
Or a JST connector works very well also
Adding the Diode If using the circuit for a motor or other inductive load a diode needs adding between the transistor Collector and Emitter. This is easily added in to the above circuit.
  1. Bend the leg on the Diode so it will fit though 0.1" hole spacing
  2. The band on the diode is to connect to the Collector and the other end to the Emitter. It will drop in to two spare holes.
  3. Solder in place and cut off the excess legs.
  4. All done. You should have something like this.
Additional notes You may also use a Mosfet for this switching circuit. A IRL3103PBF mosfet can replace the TIP120/122 Darlington transistor. The circuit is the same however the pins on a Mosfet are named Gate, Drain and Source. The mosfet fits in the same place as the Darlington with the Gate to the left (replacing the Base of the Darlington).
Updates: Edit 1 (2013.03.07): Underside of board diagram added. Edit 2 (2013.03.07): For some circuits a diode is needed as shown in the first schematic. The board here does have space for a diode (C4 to D4 - would have to be with legs bent to accommodate 0.1" spacing) however I have not shown one - watch this space:) Edit 3 (2013.03.07): Underside of board optional connections for D1 added. Edit 4 (2013.03.07): Added diode information. Edit 5 (2013.03.18): Added IRL3103 Mosfet information.
#41
Also RICH would be very helpful to others to place links to the parts you are using and costs. ome item i dont see on yours,
Mine when my design is done i have links to the costs and where to get them.
#42
Useless post, please ignore. :D
#43
PEOPLE said on my posts i did they wanted the costs for it.
#44
RICH it gives the person about how much the project will cost,and at the same tome makes it easy for the person to buy them.
In my projects it will be alot better ,instead of just USA prices ,i am adding outside country prices too.
Second nowi am called the robot santa ,i can give the parts to others for free if i have them.
I have a very large warehouse of all types of componets and even if you need them i would still give them to you.
#45
#46
OK but one or 2 links dont clog up a page . I design my circuits from memory dont use the internet to get info.
ONLY time i post info from the internet is for proof and design info.
I see it about double the price of using a mosfet instead ,and seems most here want only to dsave money and want it as cheap as possible.
main reason i put the links up to find the lowest cost and anyone doesnt have to spend time looking for the best price .
#47
