ESP32_MPU6050 icon ESP32_MPU6050 — ESP32/Arduino EZB firmware with MPU6050 support: provides accelerometer angles and Yaw/Pitch/Roll gimbal servo values for stabilization and scripting Try it →
Touch Path driving with Sabertooth
Touch Path Driving With Sabertooth
I’m running a Roli Rover with the EZB v4 over WiFi and swapped the stock Hbridge for a Sabertooth 2x12 (Simplified Serial on S1). In ARC I added the Sabertooth Movement Panel and set it to Software Serial on D5 at 9600 baud, common ground to the EZB, battery straight to Sabertooth. manual control from the Sabertooth Movement Panel works great: forward/reverse/left/right all respond smoothly and the speed sliders behave as expected.
The problem starts when I add the Touch Path skill. I set Movement Speed to 60 and Turning Speed to 40. When I draw a short Lshaped path, the debug console shows commands like:
TouchPath: Forward 1200ms @ 60
TouchPath: TurnRight 450ms @ 40
TouchPath: Forward 800ms @ 60
Sometimes Roli executes the first forward but then hesitates and either doesn’t turn at all, or turns a tiny bit and stops. Other times it completes the turn but ignores the final forward. If I immediately tap the Sabertooth panel’s arrow buttons, the rover moves, so the controller is still responsive. I tried lowering baud to 2400, increasing to 38400, tweaking Touch Path speeds up/down, and ensuring there’s only one Movement Panel in the project. I also tried moving the Sabertooth serial line to a different digital pin for software serial. Same behavior. When I switch the Sabertooth Movement Panel to use a hardware UART instead of software serial, it seems more consistent, but I still get occasional missed turns on longer paths.
Is there a recommended wiring/config/calibration workflow to make Touch Path reliably drive a Roli via the Sabertooth Movement Panel (e.g., hardware UART strongly preferred, specific speed/turn ratios, or perside trim) so that the Forward/Left/Right commands don’t get dropped?
Roli Rover by EZ-Robot
Roli Rover with Synthiam ARCx: drive with live video, control arms, follow faces, patrol, and program with Blockly or Python
Sabertooth Movement Panel by Dimension Engineering
Sabertooth movement panel: control two motors via Simplified Serial with variable speed sliders, movement buttons, and serial port options.
Touch Path by Synthiam
Sketch paths with finger or mouse and set turn/move speeds; interactive, educational demo of timing-based, sensorless robot navigation and limits.
Yes - for Touch Path + Sabertooth, the most reliable setup is usually:
1) Use Hardware UART instead of Software Serial
For timed path driving like Touch Path, hardware UART is strongly preferred. Software serial can be more sensitive to timing jitter because Touch Path is issuing timed movement changes back-to-back.
On an EZB v4, configure the Sabertooth Movement Panel to use a hardware UART if available, and match the Sabertooth baud exactly.
Sabertooth docs:
2) Make sure the Sabertooth dip switches match the baud and mode
For Simplified Serial, verify the Sabertooth 2x12 DIP switches are set for:
  • Simplified Serial
  • Correct baud rate matching ARC
If ARC is set to 9600, the Sabertooth must be set to 9600.
If you’re not sure, I’d recommend testing at the Sabertooth’s recommended Simplified Serial baud for your model and keeping ARC matched to that.
3) Keep Touch Path speeds conservative
Touch Path is timed movement, not encoder-based movement. That means the robot is never truly "measuring" whether it made the turn correctly - it’s only estimating based on time.
For a rover like Roli, try:
  • Movement Speed: 35-50
  • Turning Speed: 25-40
Your 60/40 is not crazy, but if the rover is overshooting or under-turning, reduce both and re-test.
Touch Path overview:
4) Calibrate in this order
A good workflow is:
  1. Confirm Sabertooth manual driving works
    You already did this - great.
  2. Test Touch Path with one very short line
    • Forward only
    • Then a simple right turn only
    • Then an L-shape
  3. Tune turning first If the rover turns too little, increase turning speed slightly. If it turns too much, reduce turning speed.
  4. Tune forward second If it travels too far on straight segments, reduce movement speed.
5) Expect some drift with Touch Path
Even when everything is configured correctly, Touch Path will never be as consistent as encoder-based navigation because:
  • battery voltage changes motor speed
  • floor surface affects traction
  • rover weight and wheel slip change turn distance
  • timed movement is approximate by design
So occasional slight mismatch is normal.
About the "dropped" commands
What you described - forward works, then turn hesitates or the last forward is ignored - usually points to one of these:
  • Software serial timing instability
  • baud mismatch
  • movement timing being too aggressive
  • the rover is still completing a prior motion when the next command arrives
  • turn duration is too short for that chassis
Since hardware UART improved consistency for you, that’s a strong clue that timing reliability is the issue, not the Sabertooth hardware itself.
What I would try next
Best test settings
Try this setup:
  • Sabertooth Movement Panel: Hardware UART
  • Baud: whatever your Sabertooth DIP switches are set to
  • Touch Path Movement Speed: 40
  • Touch Path Turning Speed: 30
Then test:
  • straight line
  • 90 turn
  • L-shape
  • square path
If it still under-turns, raise turning speed in steps of 5.
Wiring checklist
For the Sabertooth 2x12 in Simplified Serial:
  • Sabertooth S1 UART TX from EZB
  • GND common between EZB and Sabertooth
  • Battery directly to Sabertooth power terminals
  • No motor power from the EZB
If you use hardware UART, make sure you’re on the correct UART port in ARC’s Sabertooth configuration.
ARC note
If you want more reliable path following than Touch Path, ARC can do better with sensor feedback such as:
  • encoders
  • IMU heading correction
  • distance sensing
  • navigation messaging / autonomous logic
Touch Path is great for demo-style timed driving, but for a rover you’ll usually get better consistency by adding feedback. If needed, I can help you build a simple JavaScript-based path driver in ARC that uses timed turns plus a heading sensor for better repeatability.
If you want, I can help you with either of these next steps:
  1. Exact Sabertooth UART wiring/settings for Roli, or
  2. A Touch Path calibration table for your rover speeds and turn times.
