Neopixel Blaster icon Neopixel Blaster — DIY NeoPixel Blaster for ARC - open-source controller for up to 8×80 LEDs (640), port‑0 onboard RGB, color control via ControlCommand Try it →
Transport Track Platform And Motors To Pull 20lbs.
Transport Track Platform And Motors To Pull 20Lbs.
Hi everyone, I'm Dave, and even though I have dabbled in small robots over the years, I have regained my interest and have a few projects in mind. All that said, the first one is a little bigger then I have attempted in the past. I need some expert advise (or just advise) on a track (tank style) platform that will hold and transport around 20lbs. I have purchased the ez-robot kit and I'm afraid that the motors might not handle pulling that much weight. So, what should I do? Any suggestions?
Oh and of course, I have a limited budget, so I'm not adverse to building the platform, but would like to know what the best motors and track kit would work, and mainly if ez-robot kit can handle the control. I appreciate any guidance that you can share.
Again ... thank you everyone .... now, I just have to make some choices. You all have been very helpful, I appreciate your info and knowledge.
I'm not sure how big you're going to build your robot. The B9 builders club guys have been motorizing the tread section of their full sized 300 lb+ replicas with with wheel chair motors. They work great. You can interface them with the EZB with the Sabertooth motor controller: Sabertooth
I know this is not a ready made platform your looking for. You'll have to make your own or adapt something. Just thought I'd mention the motors and controller if you want to got hat route.
At least the Sabertooth could be your interface for a ready made platform. If you get a H-Bridge instead make sure it's AMP rating is high enough to push the motors you choose.
EDIT: Silly me, I reread your post. You want to be able to haul 20 lbs. I thought you wanted to haul 200 lbs. blush
