Inverse Kinematic Arm icon Inverse Kinematic Arm — Control robot arms with inverse and forward kinematics, converting X/Y/Z positions into joint motion and reporting end-effector location. Try it →
Trouble Connection With B4
I purchased my first development kit. I'm having trouble to connect to my network,I watched the tutorial online and contacted tech support for help. I downloaded the software on my laptop ASUS Windows 10. I clicked my network and saw ez b 4 with a synbol of a shield protection and other users, then I clicked ez b for connection. I got a response" can't connect to this network" i reseted the ez b4 by pushing the pin bottom with a pen and turned off the window defender anti spyware. I tried the procedure again i got the same message" can't connect to this network." I was advised by support group to turn off The network and try to install the connection i still got the same message.I have tried to connect with the other users on my network and I didn't have any problem. Please help!
If you can connect via your phone... flip the ezb4 into client mode... You will (should) be able to now connect to it through your router with your laptop....
Depending on the version of the EZ-B, the first initial release of the EZ-B was incompatible with a bug in the RaLink WiFi driver. Can you connect to the EZ-B with a phone over WiFi and type in this website url on the phone once connected: https://192.168.1.1
That should load the EZ-B web server on the phone. I'd like you to look on the web server main page and tell me what version is displayed. It will help to see if the EZ-B is incompatible with the RaLink driver. There is a work-around if that is the case.
DJ Sures/MazeHorizon Tech/Richard R,
I would like to thank you guys for helping me! I was able to make the connection from my phone to ez-b v4 into client mode and connected to it through my router with the laptop.
MazeHorizon Tech,
Thanks, a lot for your videos I found them very helpful.
DJ Sures,
Thank you to be so urgent to solve my problem. I am amazed how fast you replied back to me.
Richard R,
Thank you for clarify that I could connect my house router through my mobile phone.
excellent - enjoy your robot:D
