Google Speech Recognition icon Google Speech Recognition — Google Speech for ARC: cloud speech recognition with waveform, configurable response scripts and PandoraBot support Try it →
Firewall and antivirus turned off for testing? Sounds like something on your computer is stopping this process.
#10   — Edited
Also, are you saving to cloud or your computer? Do you have the same problem when you save to each?
If to your computer try to change the save path to a folder you know you can find and access. Your path may be bad.
#11   — Edited
Firewall and antivirus turned is off  -  I re-booted
This all started when I downloaded the 3 new updates
Start a project with the Bing Speech recognition, the click new - let me know what happens, thanks
I will delete my program and re-do it
I did it and it works some times
EzAng
#12   — Edited
Your first explanation of your problem said you had problems saving your project. In your lase post you mention opening a new project. Where do you actually see the problem? Is it with both actions?
I downloaded the latest ARC version. I opened my old project that has Bing Speech in it. and then clicked New. Everything worked as it should. Then I opened a new project and installed a new Bing Speech app then opened a new project. Everything worked as it should. I also saved the new project to both my computer and the cloud with no issues. I used both the Save and Save As methods with no issues.
The problem must be your installation of ARC or something on your computer keeping it from saving.
Does everything else work for yo with ARC other then saving or opening a new project?
#13   — Edited
All my programs work, except the ones with Bing Speech
solved my me today- lol
EzAng
Please delete this old post
#15
Please do not ask for posts to be deleted. It’s not easy to do
