Roomba Tones icon Roomba Tones — Deprecated Roomba control; replaced by the iRobot Roomba Movement Panel for updated movement control. Try it →
Trying To Use Ez-b And Connect To Wifi
Trying To Use Ez-B And Connect To Wifi
Purchased the recommended WiFi module from China, fired it up, populated the various fields on the configuration views, saved the changes. Connected 3.3 vdc to the module, removed the Bluetooth board on the EZB and connected the Rx, Tx leads to the WiFi module, started up the:) software application, started to connect to the WiFi with the IP address and have absolutely no clue how that is done from the connection page.
#18
One i found works perfect ,free and its not a trial version i listed in my post above
