Diagnostic Report icon Diagnostic Report — Collects and sends ARC diagnostic reports to Synthiam to help troubleshoot EZ-B and robot connection issues Try it →
Resolved Resolved by ptp!
Trying To View Foscam F19831p Ip Cam In ARC Windows Video Control?
Hello,
I visited the threads regarding viewing Foscam Video in ARC Camera Control. I have a Foscam F19831p IP Video Camera and entered the following information in the camera control device select box:
https://192.168.x.x:Port/snapshot.cgi?user=username&pwd=password
When I select start in the Camera Control I get the following error message in the camera view area:
JPGStream Read Error (there are red crosshatch lines in the display also (two horizontal and two vertical).
The Foscam F19831p is set to snapshot (JPEG) Mode. It should be noted that the camera is set to snapshot mode in tinyCam Monitor Pro Application on my cell phone. I assume that is what it will be set at unless some other program changes it. I have no other applications that I have run that would change it.
I can view the video on my cell phone and also on my laptop. When viewing on Laptop I type in https://192.168.x.x:Port and it opens up the foscam application on my laptop. Once I enter my password and username name the video shows up. However one key thing here is that I have to select the substream video stream before it will show video from camera.
I am connected successfully in the client mode as mentioned in some of the threads and this makes sense of course.
Any help on this issue would be much appreciated and thanks in advance ! Rick B.:) tired
So, reading the reviews, it appears the hardware is highly rated, just the software that is not. I had a promotional credit at Amazon, so was able to get a $12 discount, and I wanted a camera for the next time I go on vacation, so I went ahead and ordered one. Amazon prime, so it will be here today, and I will set some time aside on Sunday to figure out if it can successfully be used in ARC. From what I have been reading, the API commands may have changed since the earlier versions of the camera, and unfortunately, foscam.us removed all of the forum posts about it when they stopped providing US support for foscam, and many of the links to examples I found were all linked to that forum....
We'll get it figured out though. Either by figuring out the commands, or making a plugin.
I'm with Alan not a good support.
It seems stupid simple the API, but between broken links, user mistakes, guesses etc is difficult to reach the objective.
I'm happy with my RPI + IR Camera + PAN & TIL servo and Zoneminder software. the cost is below $100 and the RPI can be used for other stuff.
Unfortunately is not a friendly solution if you don't have Linux skills and some free time to setup the solution.
Hello ptp and the techguru
I was wondering if you could shed some light on what authentication is. I looked on the internet last night and it seems that browsers like internet explorer don't support the username and password in the url? Any clarification on what authentication is would be much appreciated.
That is awesome Alan that you have purchased my same foscam camera and that you will be looking into getting it going with ARC ! That is too cool ! I did a search on foscam F19831p cgi commands and actually did find a couple of different versions of the foscam document. Might be even better to search on foscam F19831p api commands. Looking forward to see what you come up with. Again very cool ! Rick:)
Rick,
Authentication: It was my mistake, i assumed the user & password failed and the web software asked for a user & password, but it was your first attempt and intentional (without the parameters).
one more test:
  1. after reading the user guide, it seems you don't have configured the encoder for the substream.
you need to do open a browser with the following url:
https://your_ip_address:88/cgi-bin/CGIProxy.fcgi?cmd=setSubStreamFormat&format=1&usr=your_username&pwd=your_username_password
if it works well it will return "0" in the browser, 0 means no errors.
after that you can use snapPicture2 cmd url
Thanks ptp,
I will go ahead and try this when I am at my laptop. I assume I will need to enter my port number as well? Thanks for all your help and very quick responses ! This is very awesome ! Rick:)
The manual mentions 3 default ports: 88 - http port 443 - https port 888 - onvif port
if you changed the http port replaced with your value.
if you are using https port, use the http port instead.
#16
My camera just arrived, but I won't be able to do anything with it until Sunday.
