Is there a way to permanently turn off the low battery warning?
Purple
— Edited
Vuzix Augmented Reality
— Connect Vuzix 920VR AR headset to ARC to map head movement to robot servos or drive, control camera pan/tilt; deprecated 920VR support only.
Start ARC Click on the gear in the connections block. Click the settings tab, look at bottom for box to uncheck.
You understand this is a very bad move, right? Perhaps all you need to do is lower the voltage at which the warning takes place? But don't lower it much.
It's only a bad move if running LiPo batteries. If running on a lower voltage you may be constantly receiving low level warnings when batteries are fully charged. If batteries are not Lithium based, under voltage should not permanently damage the battery.
I plan to use one of my EZ-Bs running from a USB supply, this would be 5v and would constantly sound the low warning alarm. In this instance, disabling the alarm would not cause any issues.
It all depends on circumstance.
Excellent points, Rich.
I am not using batteries and want to turn off the alarm permanently.
