hi
is there a window for talk servo with led?insteadt of inmoove mouth opens, while talking,but with a led then.
EZB Connect By Name
— Discover EZB WiFi controllers by name, auto-bind connections, avoid IP management; live discovery and multi-EZB support for ARC.
hi
Good morning Bobsheaux,
original post "talk servo" - I use these settings, I am using D0 - you an use any port number, just connect your LEDmake sure you connect you LED:
Connect the LED's Anode (+) (long side) wire to the signal (white) pin D0 of the EZ-B.
Connect the LED's Cathode (-) (short side) wire to the ground (black) pin D0 of the EZ-B.
Make sure you put the min 1 and the max 180
I made a coffee time script: - you can make any script.
SayWait("Good morning my robot crew.") sleep(60) SayWait("Are you just waking up.") sleep(60) SayWait("now that you are up.") sleep(60) SayWait("time for coffee.") sleep(60) SayWait("coffee time.") sleep(60) SayWait("come and get your 1st cup of coffee.") sleep(60) SayWait("so we can start this day.") sleep(60)
another way to use the "talk servo" - I used my "talk servo" here"
https://synthiam.com/Community/Robots/My-new-and-improved-Talk-Servo-19144
LED info is on: https://synthiam.com/Community/Tutorials/Pulse-Flash-LED-with-PWM-16230
EzAng
https://synthiam.com/Community/Tutorials/Sound-Activated-Circuits-leds-Lamps-Etc-16335 This isn't working because I can't make it stop cutting off the last few words of my phrase (making the sleep higher did nothing).
The Talk servo isn't working because I can't get it to turn off when the EZB isn't saying anything.
Why does the Sound servo only kinda-sorta work with the Speech Synthesis control, but not at all with the Bing Speech Recognition? (The Talk servo seems to work(ish) with Bing.)
In either case, the LED's too dim to see unless the robot's in total darkness (and yes, I'm using LEDs which emit VISIBLE light, not infrared).
hi bobsheau
i can see now what you mean .my led flaches very little and dont stop.
bobsheaux
got it.i can make a video if you want?
Lay it on me. I'm getting nowhere with my fiddling around...
what do you need ?
1 mouth moving with speech ? 2 or lid up a led while speeking?
bobsheaux
hope this video helps.
(Ignore the flashing eyes, they're actually staying solid, save the "blinking" every 4 seconds.)
