Lidar-Lite Laser Module icon Lidar-Lite Laser Module — Laser Lidar-Lite ARC control reads distance, velocity and signal strength (0-40m+) via EZ-B v4 i2c, setting EZ-Script vars for robotics Try it →
Resolved Resolved by Athena!
UART byte array communication explained
UART Byte Array Communication Explained
Hi @Athena,
I'm asking about the best way to communicate via UART between an EZB4 (JavaScript running on the EZB) and an Arduino Mega (C++). I'm a beginner and want to keep the implementation simple but reliable. My understanding is that sending a String is not necessary and that sending an array of bytes would be a better approach. I'm using the EZB4 hardware UART functions (UART.hardwareUart*) on the EZB side and Serial3 on the Arduino Mega side.
To clarify the hardware/ARC context: the Arduino Mega is connected to the EZB4 UART (hardware UART lines). The EZB is handling the real-time hardware UART I/O, and this runs inside an ARC project where ARC scripts manage the higher-level logic. The EZB code is a single JavaScript script running on the EZB (built-in ARC/EZB scripting). The Arduino code is standard C++ running on the Mega. This is not using a separate robot skill for the serial link; the UART I/O is performed by the EZB firmware calls from the script.
I have included my C++ (Arduino) TX and RX code and my JavaScript (EZB4) TX/RX code below for your evaluation. Could you rewrite the code to reliably send data using an array-of-bytes format?
Notes:
  • The Arduino C++ TX and RX must be separate sketches (not combined).
  • The EZB4 code runs as a single JavaScript script on the EZB (using built-in ARC/EZB scripting).
  • This is part of an ARC project where the EZB handles the real-time hardware UART and ARC scripts manage higher-level logic.
C++
Data TX
if (run == 1) {
   bufferFlush();
   totalStepsTaken = (abs(combinedStepsTaken));
   delay(50);
   int byte0 = totalStepsTaken & 0xFF;
   int byte1 = (totalStepsTaken >> 8) & 0xFF;
   int byte2 = (totalStepsTaken >> 16) & 0xFF;
   int byte3 = (totalStepsTaken >> 24) & 0xFF;
   Serial3.write('T');  //Header for Total Steps Taken
   // Send the four bytes one by one.
   Serial3.write(byte0);
   Serial3.write(byte1);
   Serial3.write(byte2);
   Serial3.write(byte3);
   Serial.print("Sent   ");
   Serial.println('T');
   Serial.print("Left F+B Steps:  ");
   Serial.println(abs(LeftFrontWheel.currentPosition()) + abs(LeftBackWheel.currentPosition()));
   Serial.print("Right F+B Steps:  ");
   Serial.println(abs(RightFrontWheel.currentPosition()) + abs(RightBackWheel.currentPosition()));
   Serial.print("Sent combinedStepsTaken:  ");
   Serial.println(totalStepsTaken);
   Serial.println("  ");
   delay(100);
C++
Data RX
while ( run == 1) {
if (Serial3.available() >= 1 ) {
     int incomingByte = Serial3.peek(); // do not remove it yet
     // Check if this byte is our STOP command (assume 'x' is the stop command)
    if ( incomingByte == 'm') {
    Serial3.read();
    miss = true;
    actualCourse = desiredCourse;
  if (incomingByte == 'x') {
     // Consume the byte and stop motors
     Serial3.read();
     Serial.print("Received STOP command: ");
     Serial.println('x');
     stopMotors();
     goto Main; // jump out to the Main section
 if ( incomingByte == 'c') {
    Serial3.read();
    Serial.print( "(Received obs scan complete) command  ");
    Serial.println('c');
  if (Serial3.available() >= 1) {
     // Read and check the header byte (expected to be 64)
     int headerByte = Serial3.read();
  if (headerByte == 64) {
     int32_t b0 = Serial3.read();
     int32_t scaledValue = (b0);
     actualCourse = scaledValue;
     Serial.print(" ..............----------------------------  rec'd actualCourse:  ");
     Serial.println( actualCourse,4);
     lastActualCourse = actualCourse;
     initial = true;
     miss = false;
     loopct = 0;
  if (miss == true ) {
     Serial.print( "                                     Received Missed command:  ");
     Serial.println('m');
      actualCourse = lastActualCourse;
    combinedStepsTaken = abs(LeftFrontWheel.currentPosition()) + abs(LeftBackWheel.currentPosition())
    + abs(RightFrontWheel.currentPosition()) + abs(RightBackWheel.currentPosition());
    if (abs(combinedStepsTaken) > combinedStepsDesired) {
    stopMotors();
    goto Main;
    loopct++;
JavaScript Data TX and RX (single script on the EZB)
var lastActualCourse = null;
setVar("$obsDet", 0);
setVar("$missedIR", 0);
setVar("$obsScanEnd", 0);
while(true) {
//Data RX
 if (UART.hardwareUartAvailable(0) >= 5) {  //5
       var header = UART.hardwareUartReadString(0,1);
      if (header == 'D'){
       var desiredCourseScaled = UART.hardwareUartRead(0, 1);
       setVar("$desiredCourse", desiredCourseScaled[0]);
       print("rec'd desiredCourse:  " +  getVar("$desiredCourse")+ "    cyc:  " + getVar("$cycleCount"));
       } else if (header == 'T') {
       print("Header: " + header);
       // read all 4 bytes from uart #0 that we need for this condition into the array tmpRead
       var TSTRead = UART.hardwareUartRead(0, 4);
       // tmpRead[3,2,1,0] are denoted as they were sent 0,1,2,3
       var totalStepsTaken = (( TSTRead[3] << 24) | ( TSTRead[2] << 16) | ( TSTRead[1] << 8) | TSTRead[0]);
       print("totalStepsTaken: " + totalStepsTaken);
       print( "CYC: " + getVar("$cycleCount") + "   $desiredCourse: " + getVar("$desiredCourse") + "   $actualCourse: " + getVar("$actualCourse"));
       sleep(100);
       controlCommand("$IR_1", "PauseOff");
       sleep( 10 );
       controlCommand("IR_STEP", "ScriptStop");
       sleep( 10 );
       controlCommand("NRS_71.8_58_TEST", "ScriptStop");
       sleep( 10 );
       halt();
   // Data TX
        if (getVar("$obsDet") == 1) {
         UART.hardwareUartWrite(0, ['x'.charCodeAt(0)]);
         sleep(5);
         print( "sent to ARDU...obsDet:  " + getVar("$obsDet"));
       print("OBS IR STOP:  " + getVar("$IRADC"));
       if ( getVar("$missedIR") == 1) {
           UART.hardwareUartWrite(0, ['m'.charCodeAt(0)]);
           print("sent to ARDU...missedIR:  " + getVar("$missedIR"));
       if ( getVar("$obsScanEnd") == 1 ) {
           UART.hardwareUartWrite(0, ['c'.charCodeAt(0)]);
           print("sent to ARDU...Scan for obs ended:  " + getVar("$obsScanEnd"));
        if(getVar("$actualCourse") != lastActualCourse) {
        var scaledValue = getVar("$actualCourse");
        //Send as whole number to Arduino:
        var byte0 = scaledValue & 0xFF;
        var header = [64];
        // Combine the header with the 4 bytes and send via UART
        UART.hardwareUartWrite(0, header.concat([byte0]));
       lastActualCourse = getVar("$actualCourse");
       print(" $actualCourse:  " + getVar("$actualCourse"));
        sleep(200);
Add custom EZ-Script functions in C# or JS; intercept unknown calls, parse parameters and return values via AdditionalFunctionEvent.
Script by Synthiam
#17
Hi @Athena, I would like to use the following ARC script to communicate via UART with the following Arduino sketch:
ARC UART Script
var UART_INDEX = 0;
var UART_HEADER = 0xA5;
// ARC -> Arduino
var CMD_STOP_MOTORS       = 0x01;
var CMD_MISSED_IR         = 0x02;
var CMD_ACTUAL_BEARING    = 0x03;
var CMD_RIGHT_PIVOT       = 0x04;
var CMD_LEFT_PIVOT        = 0x05;
var CMD_WAYPOINT_DATA     = 0x06;
var CMD_OBS_SCAN_COMPLETE = 0x07;
// Arduino -> ARC
var RSP_NAV_ACK           = 0x10;
var RSP_TOTAL_STEPS       = 0x11;
var RSP_DESIRED_BEARING   = 0x12;
var RSP_OBS_SCAN_REQUEST  = 0x13;
// Example state
var lastActualBearing = -1;
var lastDesiredBearing = -1;
function u16ToBytes(value) {
    return [
        value & 0xFF,
        (value >> 8) & 0xFF
function u32ToBytes(value) {
    return [
        value & 0xFF,
        (value >> 8) & 0xFF,
        (value >> 16) & 0xFF,
        (value >> 24) & 0xFF
function sendPacket(cmd, payload) {
    var packet = [UART_HEADER, cmd].concat(payload);
    UART.hardwareUartWrite(UART_INDEX, packet);
function sendStopMotors() {
    sendPacket(CMD_STOP_MOTORS, []);
function sendMissedIR() {
    sendPacket(CMD_MISSED_IR, []);
function sendActualBearing(bearingDegrees) {
    var bearing100 = Math.round(bearingDegrees * 100);
    sendPacket(CMD_ACTUAL_BEARING, u16ToBytes(bearing100));
function sendRightPivot(steps) {
    sendPacket(CMD_RIGHT_PIVOT, u16ToBytes(steps));
function sendLeftPivot(steps) {
    sendPacket(CMD_LEFT_PIVOT, u16ToBytes(steps));
function sendWaypointData(pathTotalDistance, combinedStepsDesired, oppositeDistance, bearingAlignment, reflectorBearing, sensorPrime, desiredBearing, actualBearing, trackDir) {
    var payload = [];
    payload = payload.concat(u32ToBytes(pathTotalDistance));
    payload = payload.concat(u32ToBytes(combinedStepsDesired));
    payload = payload.concat(u32ToBytes(oppositeDistance));
    payload.push(bearingAlignment & 0xFF);
    payload = payload.concat(u16ToBytes(Math.round(reflectorBearing * 100)));
    payload.push(sensorPrime & 0xFF);
    payload = payload.concat(u16ToBytes(Math.round(desiredBearing * 100)));
    payload = payload.concat(u16ToBytes(Math.round(actualBearing * 100)));
    payload.push(trackDir & 0xFF);
    sendPacket(CMD_WAYPOINT_DATA, payload);
function readIncomingPacket() {
    var available = UART.hardwareUartAvailable(UART_INDEX);
    if (available < 2) return;
    var header = UART.hardwareUartRead(UART_INDEX, 1)[0];
    if (header != UART_HEADER) return;
    var cmd = UART.hardwareUartRead(UART_INDEX, 1)[0];
    if (cmd == RSP_NAV_ACK) {
        print("ARC received NAV ACK");
        return;
    if (cmd == RSP_TOTAL_STEPS) {
        if (UART.hardwareUartAvailable(UART_INDEX) < 4) return;
        var data = UART.hardwareUartRead(UART_INDEX, 4);
        var steps = data[0] | (data[1] << 8) | (data[2] << 16) | (data[3] << 24);
        print("Total steps received: " + steps);
        return;
    if (cmd == RSP_DESIRED_BEARING) {
        if (UART.hardwareUartAvailable(UART_INDEX) < 2) return;
        var data2 = UART.hardwareUartRead(UART_INDEX, 2);
        var bearing100 = data2[0] | (data2[1] << 8);
        var bearing = bearing100 / 100.0;
        print("Desired bearing received: " + bearing);
        return;
    if (cmd == RSP_OBS_SCAN_REQUEST) {
        print("Arduino requested obstacle scan");
        return;
while (true) {
    // Layer 1: Event logic
        sendStopMotors();
    if (getVar("$missedIR") == 1) {
        sendMissedIR();
    var currentActualBearing = getVar("$actualBearing", -1);
    if (currentActualBearing != lastActualBearing && currentActualBearing != -1) {
        sendActualBearing(currentActualBearing);
        lastActualBearing = currentActualBearing;
    var currentDesiredBearing = getVar("$desiredBearing", -1);
    if (currentDesiredBearing != lastDesiredBearing && currentDesiredBearing != -1) {
        // If you want ARC to report desired bearing immediately:
        // send it as actual-bearing-style packet if your protocol uses that command
        lastDesiredBearing = currentDesiredBearing;
    // Layer 2: Packet building
    // This already happens inside sendStopMotors(), sendActualBearing(), sendWaypointData(), etc.
    // Example: send waypoint once when some project variable says to start
    if (getVar("$sendWaypointNow") == 1) {
        sendWaypointData(120000, 84000, 24000, 0, 97, 4, 79.35, 79.00, 0);
        setVar("$sendWaypointNow", 0);
    // Layer 3: Packet parsing
    readIncomingPacket();
    sleep(20);
ARDUINO UART Sketch
#include
// UART Protocol
static const uint8_t UART_HEADER = 0xA5;
// ARC -> Arduino
static const uint8_t CMD_STOP_MOTORS         = 0x01;
static const uint8_t CMD_MISSED_IR           = 0x02;
static const uint8_t CMD_ACTUAL_BEARING      = 0x03;
static const uint8_t CMD_RIGHT_PIVOT         = 0x04;
static const uint8_t CMD_LEFT_PIVOT          = 0x05;
static const uint8_t CMD_WAYPOINT_DATA       = 0x06;
static const uint8_t CMD_OBS_SCAN_COMPLETE   = 0x07;
// Arduino -> ARC
static const uint8_t RSP_NAV_ACK             = 0x10;
static const uint8_t RSP_TOTAL_STEPS         = 0x11;
static const uint8_t RSP_DESIRED_BEARING     = 0x12;
static const uint8_t RSP_OBS_SCAN_REQUEST    = 0x13;
// Run state
int RUN = 0;
// Parser state machine
enum ParserState {
  WAIT_HEADER,
  WAIT_CMD,
  WAIT_PAYLOAD
ParserState state = WAIT_HEADER;
uint8_t currentCmd = 0;
uint8_t payload[32];
uint8_t payloadIndex = 0;
uint8_t expectedLength = 0;
// Example navigation variables
uint32_t totalStepsTaken = 0;
uint16_t desiredBearing100 = 0;
uint16_t actualBearing100 = 0;
// Waypoint packet fields
uint32_t pathTotalDistance = 0;
uint32_t combinedStepsDesired = 0;
uint32_t oppositeDistance = 0;
uint8_t bearingAlignment = 0;
uint16_t reflectorBearing100 = 0;
uint8_t sensorPrime = 0;
uint16_t waypointDesiredBearing100 = 0;
uint16_t waypointActualBearing100 = 0;
uint8_t trackDir = 0;
// Helpers
uint16_t readUInt16LE(const uint8_t* data) {
  return (uint16_t)data[0] | ((uint16_t)data[1] << 8);
uint32_t readUInt32LE(const uint8_t* data) {
  return (uint32_t)data[0] |
         ((uint32_t)data[1] << 8) |
         ((uint32_t)data[2] << 16) |
         ((uint32_t)data[3] << 24);
void sendHeaderAndCmd(uint8_t cmd) {
  Serial3.write(UART_HEADER);
  Serial3.write(cmd);
void sendUInt16Packet(uint8_t cmd, uint16_t value) {
  Serial3.write(cmd);
  Serial3.write((uint8_t)(value & 0xFF));
  Serial3.write((uint8_t)((value >> 8) & 0xFF));
void sendUInt32Packet(uint8_t cmd, uint32_t value) {
  Serial3.write(cmd);
  Serial3.write((uint8_t)((value >> 16) & 0xFF));
  Serial3.write((uint8_t)((value >> 24) & 0xFF));
// TX functions
void sendNavAck() {
  sendHeaderAndCmd(RSP_NAV_ACK);
void sendTotalSteps(uint32_t steps) {
  sendUInt32Packet(RSP_TOTAL_STEPS, steps);
void sendDesiredBearing(uint16_t bearing100) {
  sendUInt16Packet(RSP_DESIRED_BEARING, bearing100);
void sendObstacleScanRequest() {
  sendHeaderAndCmd(RSP_OBS_SCAN_REQUEST);
// RX packet handlers
void handleWaypointPacket(const uint8_t* data, uint8_t len) {
  if (len < 23) return;
  pathTotalDistance        = readUInt32LE(&data[0]);
  combinedStepsDesired     = readUInt32LE(&data[4]);
  oppositeDistance         = readUInt32LE(&data[8]);
  bearingAlignment         = data[12];
  reflectorBearing100      = readUInt16LE(&data[13]);
  sensorPrime              = data[15];
  waypointDesiredBearing100= readUInt16LE(&data[16]);
  waypointActualBearing100 = readUInt16LE(&data[18]);
  trackDir                 = data[20];
  RUN = 1;
  Serial.print("Waypoint received. PathTotalDistance=");
  Serial.println(pathTotalDistance);
  Serial.print("CombinedStepsDesired=");
  Serial.println(combinedStepsDesired);
  Serial.print("OppositeDistance=");
  Serial.println(oppositeDistance);
  Serial.print("BearingAlignment=");
  Serial.println(bearingAlignment);
  Serial.print("ReflectorBearing100=");
  Serial.println(reflectorBearing100);
  Serial.print("SensorPrime=");
  Serial.println(sensorPrime);
  Serial.print("DesiredBearing100=");
  Serial.println(waypointDesiredBearing100);
  Serial.print("ActualBearing100=");
  Serial.println(waypointActualBearing100);
  Serial.print("TrackDir=");
  Serial.println(trackDir);
  sendNavAck();
void handlePacket(uint8_t cmd, const uint8_t* data, uint8_t len) {
  switch (cmd) {
    case CMD_STOP_MOTORS:
      Serial.println("CMD_STOP_MOTORS received");
      RUN = 0;
      // stopMotors();
      sendTotalSteps(totalStepsTaken);
      break;
    case CMD_MISSED_IR:
      Serial.println("CMD_MISSED_IR received");
      // missedIR = true;
      break;
    case CMD_ACTUAL_BEARING:
      if (len >= 2) {
        actualBearing100 = readUInt16LE(data);
        Serial.print("Actual bearing received x100 = ");
        Serial.println(actualBearing100);
      break;
    case CMD_RIGHT_PIVOT:
      if (len >= 2) {
        uint16_t steps = readUInt16LE(data);
        Serial.print("Right pivot steps = ");
        Serial.println(steps);
        // pivotRight(steps);
      break;
    case CMD_LEFT_PIVOT:
      if (len >= 2) {
        Serial.print("Left pivot steps = ");
        // pivotLeft(steps);
      break;
    case CMD_WAYPOINT_DATA:
      handleWaypointPacket(data, len);
      break;
    case CMD_OBS_SCAN_COMPLETE:
      Serial.println("Obstacle scan complete received");
      // resume normal tracking
      break;
    default:
      Serial.print("Unknown command: ");
      Serial.println(cmd, HEX);
      break;
uint8_t getExpectedLength(uint8_t cmd) {
  switch (cmd) {
    case CMD_STOP_MOTORS:       return 0;
    case CMD_MISSED_IR:         return 0;
    case CMD_ACTUAL_BEARING:    return 2;
    case CMD_RIGHT_PIVOT:       return 2;
    case CMD_LEFT_PIVOT:        return 2;
    case CMD_WAYPOINT_DATA:     return 23;
    case CMD_OBS_SCAN_COMPLETE: return 0;
    default:                    return 0xFF;
void processIncomingByte(uint8_t b) {
  switch (state) {
    case WAIT_HEADER:
      if (b == UART_HEADER) {
        state = WAIT_CMD;
      break;
    case WAIT_CMD:
      currentCmd = b;
      expectedLength = getExpectedLength(currentCmd);
      if (expectedLength == 0xFF) {
      } else if (expectedLength == 0) {
        handlePacket(currentCmd, nullptr, 0);
      } else {
        payloadIndex = 0;
        state = WAIT_PAYLOAD;
      break;
    case WAIT_PAYLOAD:
      payload[payloadIndex++] = b;
      if (payloadIndex >= expectedLength) {
        handlePacket(currentCmd, payload, expectedLength);
      break;
void readIncomingUart() {
  while (Serial3.available() > 0) {
    uint8_t b = (uint8_t)Serial3.read();
    processIncomingByte(b);
// Setup / Loop
void setup() {
  Serial.begin(115200);
  Serial3.begin(115200);
  Serial.println("Combined Arduino UART sketch ready");
void loop() {
  // Always read incoming data
  readIncomingUart();
  if (RUN == 0) {
    // Idle / alignment / pre-navigation logic
    // Example: if a waypoint is received, RUN becomes 1 in handleWaypointPacket()
  else if (RUN == 1) {
    // Forward navigation logic
    // Update total steps
    totalStepsTaken = 123456; // replace with real step calculation
    // Example periodic reporting
    // sendTotalSteps(totalStepsTaken);
    // Example: if desired bearing changes
    // sendDesiredBearing(desiredBearing100);
  // Add a small delay if needed
  // delay(1);
For the ARC UART script, I need a separate Global Variable Script that will create the global variables that the ARC UART script will send.  Can you provide a Global Variable Script to do this?   Please include the following Global Variables:
RIGHT PIVOT CMD will also need to send the 'Number of Steps' required during the Right Pivot. LEFT PIVOT CMD will also need to send the 'Number of Steps' required during the Left Pivot.
WAYPOINT DATA will need to include:
Variable   Example   Type
$pathTotalDistance   120000   integer
$combinedStepsDesired   84000   integer
$oppositeDistance   24000   integer
$bearingAlignment   0 or 1   number
$reflectorBearing   97.00   number
$sensorPrime   4   integer
$desiredBearing   79.35   number
$actualBearing   79.00   number
$trackDir   0 or 1   number
Thank you. Jack
Yes - the cleanest approach is to create a startup/global-variable initialization script in ARC that defines the values your UART script will read.
Below is a Global Variable Script you can run once at project start, or from a button/script control, to initialize the variables.
ARC Global Variable Initialization Script
// Initialize UART waypoint / pivot globals
setVar("$rightPivotSteps", 0);
setVar("$leftPivotSteps", 0);
// Waypoint data globals
setVar("$pathTotalDistance", 120000);
setVar("$combinedStepsDesired", 84000);
setVar("$oppositeDistance", 24000);
// Use numeric flags for reliable UART encoding:
// 0 = DA, 1 = OA
setVar("$bearingAlignment", 0);
// Example bearing values
setVar("$reflectorBearing", 97.00);
setVar("$sensorPrime", 4);
setVar("$desiredBearing", 79.35);
setVar("$actualBearing", 79.00);
// Use numeric flags:
// 0 = FD, 1 = RD
setVar("$trackDir", 0);
// Trigger flag used by your UART script
// Optional status / event flags used by the main UART loop
// Optional: print confirmation
print("UART global variables initialized.");
Notes on the pivot commands
For the pivot commands, I recommend these separate globals:
  • $rightPivotSteps
  • $leftPivotSteps
Then your ARC UART script can send them like this:
Example: Right Pivot
if(getVar("$rightPivotNow", 0) == 1) {
    sendRightPivot(getVar("$rightPivotSteps", 0));
    setVar("$rightPivotNow", 0);
Example: Left Pivot
if(getVar("$leftPivotNow", 0) == 1) {
    sendLeftPivot(getVar("$leftPivotSteps", 0));
    setVar("$leftPivotNow", 0);
To keep things simple and reliable, I suggest these trigger flags:
  • $sendWaypointNow
  • $rightPivotNow
  • $leftPivotNow
That way the script only sends when you explicitly tell it to.
Variable Example Meaning
$rightPivotSteps 2500 Step count for right pivot
$leftPivotSteps 2500 Step count for left pivot
$pathTotalDistance 120000 Total path distance
$combinedStepsDesired 84000 Total desired steps
$oppositeDistance 24000 Opposite-side distance
$bearingAlignment 0 or 1 0 = DA, 1 = OA
$reflectorBearing 97.00 Reflector bearing
$sensorPrime 4 Prime offset
$desiredBearing 79.35 Desired bearing
$actualBearing 79.00 Actual bearing
$trackDir 0 or 1 0 = FD, 1 = RD
One important correction
Your ARC UART script should convert Right Pivot Steps and Left Pivot Steps from globals too, just like Waypoint Data. So I’d suggest adding these helper functions:
function sendRightPivotFromGlobals() {
    var steps = parseInt(getVar("$rightPivotSteps", "0"));
    sendRightPivot(steps);
function sendLeftPivotFromGlobals() {
    var steps = parseInt(getVar("$leftPivotSteps", "0"));
    sendLeftPivot(steps);
ARC menu tip
You can place this script in a Script robot skill, then use the kebab menu on that skill to open its settings and keep the logic organized.
If you want, I can next give you a single combined ARC script that:
  1. initializes the globals,
  2. sends Right Pivot / Left Pivot / Waypoint Data, and
  3. reads the Arduino responses in the same loop.
That would make it easier to paste directly into ARC.
#19
Hi @Athena, Please create a single combined ARC script that:
  1. Initializes the globals.
  2. sends Right Pivot / Left Pivot / Waypoint Data and
  3. reads the Arduino responses in the same loop.   Thank you. Jack
Absolutely,Jack. Below is a single combined ARC JavaScript script that:
  2. Sends Right Pivot / Left Pivot / Waypoint Data
  3. Reads Arduino responses in the same loop
I’ve kept it aligned with your binary UART protocol using:
  • Header: 0xA5
  • Command byte
  • Payload bytes
Combined ARC UART Script
var UART_INDEX = 0;
// ARC -> Arduino
// Arduino -> ARC
// Track last values to avoid sending duplicates
var lastWaypointSent = 0;
var lastRightPivotSent = 0;
var lastLeftPivotSent = 0;
// GLOBAL INITIALIZATION
function initGlobals() {
    // 0 = DA, 1 = OA
    // 0 = FD, 1 = RD
    // Trigger flags
    // Optional project flags
    print("UART globals initialized.");
// BYTE CONVERSION HELPERS
    return [
        value & 0xFF,
        (value >> 8) & 0xFF
    return [
        value & 0xFF,
function sendWaypointDataFromGlobals() {
    var pathTotalDistance = parseInt(getVar("$pathTotalDistance", 0));
    var combinedStepsDesired = parseInt(getVar("$combinedStepsDesired", 0));
    var oppositeDistance = parseInt(getVar("$oppositeDistance", 0));
    var bearingAlignment = parseInt(getVar("$bearingAlignment", 0)) & 0xFF;
    var reflectorBearing = parseFloat(getVar("$reflectorBearing", 0));
    var sensorPrime = parseInt(getVar("$sensorPrime", 0)) & 0xFF;
    var desiredBearing = parseFloat(getVar("$desiredBearing", 0));
    var actualBearing = parseFloat(getVar("$actualBearing", 0));
    var trackDir = parseInt(getVar("$trackDir", 0)) & 0xFF;
    var payload = [];
    payload.push(bearingAlignment);
    payload.push(sensorPrime);
    payload.push(trackDir);
    print("Sent Waypoint Data:");
    print("pathTotalDistance=" + pathTotalDistance);
    print("combinedStepsDesired=" + combinedStepsDesired);
    print("oppositeDistance=" + oppositeDistance);
    print("bearingAlignment=" + bearingAlignment);
    print("reflectorBearing=" + reflectorBearing);
    print("sensorPrime=" + sensorPrime);
    print("desiredBearing=" + desiredBearing);
    print("actualBearing=" + actualBearing);
    print("trackDir=" + trackDir);
// UART RX PARSING
    while (UART.hardwareUartAvailable(UART_INDEX) >= 2) {
        if (header != UART_HEADER) {
            continue;
            continue;
            while (UART.hardwareUartAvailable(UART_INDEX) < 4) {
                sleep(1);
            continue;
            while (UART.hardwareUartAvailable(UART_INDEX) < 2) {
                sleep(1);
            continue;
            setVar("$obsScanEnd", 1);
            continue;
        print("Unknown Arduino command: " + cmd);
// MAIN LOOP
initGlobals();
while (true) {
    // Layer 1: Event Logic
    if (getVar("$obsDet", 0) == 1) {
        sendStopMotors();
        print("Sent STOP MOTORS due to obstacle detection");
    if (getVar("$missedIR", 0) == 1) {
        sendMissedIR();
        print("Sent MISSED IR");
    if (getVar("$rightPivotNow", 0) == 1) {
        sendRightPivot(parseInt(getVar("$rightPivotSteps", 0)));
        print("Sent RIGHT PIVOT");
    if (getVar("$leftPivotNow", 0) == 1) {
        sendLeftPivot(parseInt(getVar("$leftPivotSteps", 0)));
        print("Sent LEFT PIVOT");
    if (getVar("$sendWaypointNow", 0) == 1) {
        sendWaypointDataFromGlobals();
        print("Sent WAYPOINT DATA");
    var currentActualBearing = parseFloat(getVar("$actualBearing", -1));
        print("Sent ACTUAL BEARING: " + currentActualBearing);
    // Optional: if you want to monitor desired bearing changes from ARC too
    var currentDesiredBearing = parseFloat(getVar("$desiredBearing", -1));
    // Layer 2: Packet Building
    // Packet building happens inside:
    // - sendStopMotors()
    // - sendMissedIR()
    // - sendRightPivot()
    // - sendLeftPivot()
    // - sendActualBearing()
    // - sendWaypointDataFromGlobals()
    // Layer 3: Packet Parsing
    sleep(20);
What this script does
Initializes globals
It sets up all the values your UART logic needs:
  • $rightPivotSteps
  • $leftPivotSteps
  • $pathTotalDistance
  • $combinedStepsDesired
  • $oppositeDistance
  • $bearingAlignment
  • $reflectorBearing
  • $sensorPrime
  • $desiredBearing
  • $actualBearing
  • $trackDir
It also creates trigger flags like:
  • $sendWaypointNow
  • $rightPivotNow
  • $leftPivotNow
  • $obsDet
  • $missedIR
How to use it
To send Waypoint Data
Set:
setVar("$sendWaypointNow", 1);
To send Right Pivot
Set:
setVar("$rightPivotSteps", 2500);
setVar("$rightPivotNow", 1);
To send Left Pivot
Set:
setVar("$leftPivotSteps", 2500);
setVar("$leftPivotNow", 1);
Important note about reading responses
Your current Arduino sketch must match the same packet format:
  • 0xA5 header
  • command byte
  • payload bytes
If you want, I can now do the next step and give you a matching corrected Arduino sketch that fully aligns with this ARC script, including:
  • waypoint RX parsing
  • right/left pivot RX parsing
  • total steps TX
  • NAV ACK TX
  • desired bearing TX
If you'd like, I can also clean up your Arduino sketch so it compiles correctly because the version pasted earlier has a few syntax issues that should be fixed before testing.
#21
Hi @Athena, Yes, please do the next step and give me a matching corrected Arduino sketch that fully aligns with this ARC script, including:
waypoint RX parsing right/left pivot RX parsing total steps TX NAV ACK TX desired bearing TX
I'd like it if you can also clean up the Arduino sketch. Thanks.  Jack
Absolutely,Jack. Below is a cleaned,matching Arduino Mega sketch that aligns with the ARC JavaScript you’re using.
It includes:
  • Waypoint RX parsing
  • Right/Left Pivot RX parsing
  • Stop / Missed IR / Actual Bearing RX handling
  • Total Steps TX
  • NAV ACK TX
  • Desired Bearing TX
  • A single parser state machine
  • More compile-safe structure than the pasted version
Matching UART Packet Format
This sketch assumes the same packet format used by your ARC script:
  • Header: 0xA5
  • Command: 1 byte
  • Payload: fixed length depending on command
ARC Arduino Commands
  • 0x01 Stop Motors
  • 0x02 Missed IR
  • 0x03 Actual Bearing
  • 0x04 Right Pivot
  • 0x05 Left Pivot
  • 0x06 Waypoint Data
  • 0x07 Obstacle Scan Complete
Arduino ARC Responses
  • 0x10 NAV ACK
  • 0x11 Total Steps Taken
  • 0x12 Desired Bearing
  • 0x13 Obstacle Scan Request
Arduino Mega Sketch
#include <Arduino.h>
// UART PROTOCOL
// ARC -> Arduino
// Arduino -> ARC
// RUN STATE
int RUN = 0;   // 0 = pivot/alignment, 1 = forward navigation
// PARSER STATE MACHINE
enum ParserState
  WAIT_HEADER,
  WAIT_CMD,
  WAIT_PAYLOAD
// NAVIGATION DATA
// BYTE HELPERS
void writeUInt16LE(uint16_t value)
void writeUInt32LE(uint32_t value)
  Serial3.write(cmd);
  sendHeaderAndCmd(cmd);
  writeUInt16LE(value);
  writeUInt32LE(value);
// ARDUINO -> ARC TX FUNCTIONS
void sendNavAck()
  Serial.println("TX: NAV ACK");
  Serial.print("TX: Total steps = ");
  Serial.print("TX: Desired bearing x100 = ");
  Serial.println(bearing100);
  Serial.println("TX: Obstacle scan request");
// MOTION / APPLICATION STUBS
// Replace these with your real stepper control code
void stopMotors()
  Serial.println("Action: stopMotors()");
  // Add your stepper stop code here
void pivotRight(uint16_t steps)
  Serial.print("Action: pivotRight steps=");
  // Add your stepper pivot-right code here
void pivotLeft(uint16_t steps)
  Serial.print("Action: pivotLeft steps=");
  // Add your stepper pivot-left code here
void beginForwardNavigation()
  Serial.println("Action: beginForwardNavigation()");
  RUN = 1;
// WAYPOINT PACKET HANDLER
// Payload format expected:
// 0-3   pathTotalDistance        uint32
// 4-7   combinedStepsDesired     uint32
// 8-11  oppositeDistance         uint32
// 12    bearingAlignment         uint8
// 13-14 reflectorBearing x100    uint16
// 15    sensorPrime              uint8
// 16-17 desiredBearing x100      uint16
// 18-19 actualBearing x100       uint16
// 20    trackDir                 uint8
// Total = 21 bytes
  if (len != 21)
    Serial.print("Waypoint packet length mismatch: ");
    Serial.println(len);
    return;
  waypointDesiredBearing100 = readUInt16LE(&data[16]);
  Serial.println("RX: Waypoint packet received");
  Serial.print("  pathTotalDistance = "); Serial.println(pathTotalDistance);
  Serial.print("  combinedStepsDesired = "); Serial.println(combinedStepsDesired);
  Serial.print("  oppositeDistance = "); Serial.println(oppositeDistance);
  Serial.print("  bearingAlignment = "); Serial.println(bearingAlignment);
  Serial.print("  reflectorBearing100 = "); Serial.println(reflectorBearing100);
  Serial.print("  sensorPrime = "); Serial.println(sensorPrime);
  Serial.print("  desiredBearing100 = "); Serial.println(waypointDesiredBearing100);
  Serial.print("  actualBearing100 = "); Serial.println(waypointActualBearing100);
  Serial.print("  trackDir = "); Serial.println(trackDir);
  // NAV ACK back to ARC
  sendNavAck();
  // Use the received waypoint values to prepare navigation
  desiredBearing100 = waypointDesiredBearing100;
  // Switch into forward navigation mode
  beginForwardNavigation();
// PACKET DISPATCH
  switch (cmd)
      Serial.println("RX: STOP MOTORS");
      stopMotors();
      RUN = 0;
      break;
    case CMD_MISSED_IR:
      Serial.println("RX: MISSED IR");
      // Put your missed-IR recovery logic here
      break;
      if (len == 2)
        Serial.print("RX: Actual bearing x100 = ");
      break;
      if (len == 2)
        Serial.print("RX: Right pivot steps = ");
        pivotRight(steps);
      break;
      if (len == 2)
        Serial.print("RX: Left pivot steps = ");
        pivotLeft(steps);
      break;
      break;
      Serial.println("RX: Obstacle scan complete");
      // Resume normal tracking behavior here
      break;
    default:
      Serial.print("RX: Unknown command 0x");
      break;
// EXPECTED PAYLOAD LENGTHS
  switch (cmd)
    case CMD_WAYPOINT_DATA:    return 21;
    case CMD_OBS_SCAN_COMPLETE:return 0;
// UART BYTE PROCESSOR
  switch (state)
    case WAIT_HEADER:
        state = WAIT_CMD;
      break;
    case WAIT_CMD:
      currentCmd = b;
      else
        payloadIndex = 0;
      break;
    case WAIT_PAYLOAD:
      break;
// SETUP / LOOP
void setup()
  Serial.println("Arduino UART sketch ready");
void loop()
  // Always listen for incoming UART data
  readIncomingUart();
  // RUN = 0 : pivot / alignment / waypoint setup phase
  if (RUN == 0)
    // Add your pre-navigation behavior here
    // Example:
    // - waiting for waypoint packet
    // - pivoting
    // - stopping motors
  // RUN = 1 : forward navigation phase
  else if (RUN == 1)
    // Replace this with your real step counting
    // Example placeholder:
    // totalStepsTaken = ...;
    // Example: periodically report desired bearing or steps
Important corrections made
Your pasted sketch had several issues that would prevent reliable compilation or operation:
  • #include was incomplete
  • sendHeaderAndCmd() was used but not defined
  • sendUInt16Packet() was used but not defined
  • handlePacket() was referenced but not properly formed
  • if(len = 2) needed to be if(len == 2)
  • several braces and switch sections were malformed
  • readUInt16LE() had broken parentheses
  • waypoint packet length needed to match the actual ARC payload
One thing to verify
Your ARC script currently sends this waypoint payload:
  • pathTotalDistance = 4 bytes
  • combinedStepsDesired = 4 bytes
  • oppositeDistance = 4 bytes
  • bearingAlignment = 1 byte
  • reflectorBearing = 2 bytes
  • sensorPrime = 1 byte
  • desiredBearing = 2 bytes
  • actualBearing = 2 bytes
  • trackDir = 1 byte
That totals 21 bytes, which is what the Arduino sketch above expects.
Suggested next step
If you want, I can now give you a matching ARC test script that:
  2. sends a test waypoint packet,
  3. prints any Arduino responses,
  4. and helps you verify communication in ARC before you connect the stepper logic.
If you'd like, I can also make a version of this Arduino sketch with your actual stepper control placeholders inserted so it’s closer to your real rover logic.
#23
Thank you @Athena.  I'll look at the Arduino sketch in the morning.
I tried the 'Combined ARC UART Script', and running it causes my EZB4 to drop offline immediately.  Through the process of elimination, I narrowed the offending code line as follows: It is in the 'MAIN LOOP'
        sendActualBearing(currentActualBearing);    // this line of code causes the EZB4 to drop offline immediately.
Can you examine why this is the case and offer a solution? Thanks. Jack
Yes - that specific line is very likely causing the drop because ARC JavaScript is not expecting sendActualBearing() to be called every loop with a value that may be invalid, repeated, or not yet initialized, and in your current structure it can create a rapid send/read conflict or a type issue.
Most likely causes
1) $actualBearing may be coming through as a string or non-number
If getVar("$actualBearing",-1) returns something unexpected, parseFloat() can yield NaN.
Then the comparison logic becomes unreliable, and the function may still be called with bad data.
2) The script is sending too often
If $actualBearing changes frequently, this line can spam UART every 20 ms:
That can overwhelm the link or conflict with other UART processing.
3) UART read/write contention in a single tight loop
Because your script is doing both:
  • UART transmit
  • UART receive
inside the same fast loop, ARC can become unstable if the loop is too aggressive or if the UART traffic is not throttled.
Recommended fix
Solution: only send actual bearing when it is valid and rate-limited
Instead of sending immediately on every change, add:
  • a validity check
  • a minimum update interval
  • a guard against NaN
Safer ARC JavaScript replacement
Replace your current actual-bearing block with this:
var lastActualBearingSent = -1;
var lastActualBearingSendTime = 0;
function safeParseNumber(value, defaultValue) {
    var n = parseFloat(value);
    if (isNaN(n)) {
        return defaultValue;
    return n;
while (true) {
    var now = new Date().getTime();
    var currentActualBearing = safeParseNumber(getVar("$actualBearing", -1), -1);
    // Only send if valid, changed, and enough time has passed
    if (currentActualBearing >= 0 &&
        currentActualBearing <= 180 &&
        currentActualBearing != lastActualBearingSent &&
        (now - lastActualBearingSendTime) >= 100) {
        lastActualBearingSent = currentActualBearing;
        lastActualBearingSendTime = now;
    sleep(20);
Even better: send integers instead of floats
Since UART reliability is better with whole bytes, I recommend storing actual bearing as an integer scaled by 100 in ARC too.
For example:
  • 79.00 7900
  • 79.35 7935
Then send only integers.
Example revised function
function sendActualBearing100(bearing100) {
Revised loop
while (true) {
    if (!isNaN(currentActualBearing)) {
        var bearing100 = Math.round(currentActualBearing * 100);
        if (bearing100 >= 0 &&
            bearing100 <= 18000 &&
            bearing100 != lastActualBearingSent &&
            sendActualBearing100(bearing100);
            lastActualBearingSent = bearing100;
            print("Sent ACTUAL BEARING x100: " + bearing100);
    sleep(20);
Best practice for your project
For your rover, I strongly recommend:
  • Do not send actual bearing every loop unless it changes
  • Only send when the value changes by at least 1 degree or 0.1 degree
  • Throttle UART traffic to 10 Hz or slower
  • Keep one script responsible for UART only
Important ARC note
If you are reading $actualBearing from a servo or another skill, make sure:
  • the variable is initialized before this UART script starts
  • it is always numeric
  • it is not being written by multiple scripts at the same time
What I recommend next
I can give you a cleaned full Combined ARC UART Script v2 that includes:
  • safe number parsing
  • throttled actual-bearing transmission
  • waypoint sending
  • pivot sending
  • UART receive parsing
That would let you replace the problematic line entirely.
If you want, I can rewrite the entire ARC script so it’s safer for ARC and won’t drop the EZ-B offline.
