Inverted Pendulum icon Inverted Pendulum — Balancing controller for Sainsmart v3 (and compatible) robots: PID tuning, real‑time telemetry, angle offset, movement and calibration via ARC. Try it →
Resolved Resolved by Athena!
UART_v6 subject line options:- UART_v6 Waypoint Be…
UART_V6 Subject Line Options:- UART_V6 Waypoint Be…
Hi @Athena,
I'm trying to make an ARC UART script that works seamlessly with an Arduino Mega. Both scripts are reproduced below. A few important constraints and clarifications:
  • For WAYPOINT DATA only: in ARC the variables $actualBearing100 and $desiredBearing100 must be the same value and equal to Servo.getPosition(d17, 0) * 100.
  • After WAYPOINT DATA is sent by the ARC UART script (UART_v6), ARC (my IR_TRACKER robot skill / script) computes $actualBearing100. The Arduino computes $desiredBearing100. These values are not read as servo positions on the Arduino - they are assigned and exchanged via ARC global variables (setVar / getVar).
  • The ARC UART_v6 robot skill picks up and sets ARC globals (getVar / setVar). The Arduino communicates over Serial3 in the sketch. The connection model appears to be a hardware UART between ARC (JavaScript running as a Robot Skill) and the Arduino Mega (Serial3).
Request:
  1. Can you rewrite a clean, full UART_v6 script (comments removed) that incorporates the difference in how $actualBearing and $desiredBearing are produced, and that matches exactly the accompanying ARDUINO_v6 sketch?
Thank you, Jack
ARDUINO_v6
#include <AccelStepper.h>
#include <MultiStepper.h>
// Protocol
static const uint8_t UART_HEADER = 0xA5; // ARC -> Arduino
static const uint8_t CMD_STOP_MOTORS    = 0x01;
static const uint8_t CMD_ACTUAL_BEARING = 0x03;
static const uint8_t CMD_RIGHT_PIVOT    = 0x04;
static const uint8_t CMD_LEFT_PIVOT     = 0x05;
static const uint8_t CMD_WAYPOINT_DATA  = 0x06;
// Arduino -> ARC
static const uint8_t RSP_NAV_ACK           = 0x10;
static const uint8_t RSP_TOTAL_STEPS       = 0x11;
static const uint8_t RSP_DESIRED_BEARING   = 0x12;
static const uint8_t RSP_OBS_SCAN_REQUEST  = 0x13;
static const uint8_t MAX_PAYLOAD = 32;
// Motors
AccelStepper LeftFrontWheel(AccelStepper::DRIVER, 3, 6);
AccelStepper LeftBackWheel(AccelStepper::DRIVER, 2, 5);
AccelStepper RightFrontWheel(AccelStepper::DRIVER, 12, 13);
AccelStepper RightBackWheel(AccelStepper::DRIVER, 4, 7);
MultiStepper multiStepper;
// Parser state
enum ParserState { WAIT_HEADER, WAIT_CMD, WAIT_LEN, WAIT_PAYLOAD, WAIT_CHECKSUM };
ParserState parserState = WAIT_HEADER;
uint8_t currentCmd = 0;
uint8_t expectedLen = 0;
uint8_t payloadIndex = 0;
uint8_t payload[MAX_PAYLOAD];
uint8_t runningChecksum = 0;
// Navigation state
bool navRunning = false;
bool scanNeutralMode = false;
uint32_t totalStepsTaken = 0;
uint32_t combinedStepsDesired = 0;
uint32_t pathTotalDistance = 0;
uint32_t oppositeDistance = 0;
uint32_t nextScanStep = 10500;
const uint32_t scanIntervalSteps = 10500;
uint8_t bearingAlignment = 0;
uint8_t trackDir = 0;
uint16_t actualBearing100 = 9000;
uint16_t desiredBearing100 = 9000;
uint16_t lastSentDesiredBearing100 = 0xFFFF;
int16_t bearingDiffTarget = 0;
int16_t bearingDiffRamped = 0;
uint16_t currentSpeed = 0;
uint16_t normalSpeed = 800;
// Byte helpers
uint16_t readUInt16LE(const uint8_t* data) {
  return (uint16_t)data[0] | ((uint16_t)data[1] << 8);
uint32_t readUInt32LE(const uint8_t* data) {
  return (uint32_t)data[0] |
         ((uint32_t)data[1] << 8) |
         ((uint32_t)data[2] << 16) |
         ((uint32_t)data[3] << 24);
void writeUInt16LE(uint16_t value) {
  Serial3.write((uint8_t)(value & 0xFF));
  Serial3.write((uint8_t)((value >> 8) & 0xFF));
void writeUInt32LE(uint32_t value) {
  Serial3.write((uint8_t)((value >> 16) & 0xFF));
  Serial3.write((uint8_t)((value >> 24) & 0xFF));
// Protocol helpers
uint8_t checksumXor(uint8_t cmd, uint8_t len, const uint8_t* data) {
  uint8_t c = cmd ^ len;
  for (uint8_t i = 0; i < len; i++) {
    c ^= data[i];
  return c;
void sendPacket(uint8_t cmd, const uint8_t* data, uint8_t len) {
  Serial3.write(UART_HEADER);
  Serial3.write(cmd);
  Serial3.write(len);
    Serial3.write(data[i]);
  Serial3.write(checksumXor(cmd, len, data));
void sendCmdOnly(uint8_t cmd) {
  sendPacket(cmd, nullptr, 0);
void sendNavAck() {
  sendCmdOnly(RSP_NAV_ACK);
  Serial.println("TX: NAV ACK");
void sendTotalSteps(uint32_t steps) {
  uint8_t tmp[4];
  tmp[0] = (uint8_t)(steps & 0xFF);
  tmp[1] = (uint8_t)((steps >> 8) & 0xFF);
  tmp[2] = (uint8_t)((steps >> 16) & 0xFF);
  tmp[3] = (uint8_t)((steps >> 24) & 0xFF);
  sendPacket(RSP_TOTAL_STEPS, tmp, 4);
  Serial.print("TX: TOTAL STEPS = ");
  Serial.println(steps);
void sendDesiredBearing(uint16_t bearing100) {
  uint8_t tmp[2];
  tmp[0] = (uint8_t)(bearing100 & 0xFF);
  tmp[1] = (uint8_t)((bearing100 >> 8) & 0xFF);
  sendPacket(RSP_DESIRED_BEARING, tmp, 2);
  lastSentDesiredBearing100 = bearing100;
  Serial.print("TX: DESIRED BEARING x100 = ");
  Serial.println(bearing100);
void sendObstacleScanRequest() {
  sendCmdOnly(RSP_OBS_SCAN_REQUEST);
  Serial.println("TX: OBSTACLE SCAN REQUEST");
// Motor helpers
void resetStepperPositions() {
  LeftFrontWheel.setCurrentPosition(0);
  LeftBackWheel.setCurrentPosition(0);
  RightFrontWheel.setCurrentPosition(0);
  RightBackWheel.setCurrentPosition(0);
void setAllMotorSpeeds(int leftSpeed, int rightSpeed) {
  leftSpeed = constrain(leftSpeed, 0, 2000);
  rightSpeed = constrain(rightSpeed, 0, 2000);
  LeftFrontWheel.setSpeed(leftSpeed);
  LeftBackWheel.setSpeed(leftSpeed);
  RightFrontWheel.setSpeed(rightSpeed);
  RightBackWheel.setSpeed(rightSpeed);
void stopMotors() {
  LeftFrontWheel.stop();
  LeftBackWheel.stop();
  RightFrontWheel.stop();
  RightBackWheel.stop();
  LeftFrontWheel.setSpeed(0);
  LeftBackWheel.setSpeed(0);
  RightFrontWheel.setSpeed(0);
  RightBackWheel.setSpeed(0);
  Serial.println("Action: stopMotors()");
void resetNavigationState() {
  resetStepperPositions();
  nextScanStep = scanIntervalSteps;
  currentSpeed = 0;
  navRunning = false;
  Serial.println("Navigation state reset");
void beginForwardNavigation() {
  navRunning = true;
  currentSpeed = 0;
// Navigation math
void computeDesiredBearing() {
  if (bearingAlignment == 0) {
    return;
  uint32_t pathDistanceRemaining = 1;
  if (trackDir == 0) {
    if (pathTotalDistance > totalStepsTaken) {
      pathDistanceRemaining = pathTotalDistance - totalStepsTaken;
  } else {
    uint32_t remainingSteps = (combinedStepsDesired > totalStepsTaken)
      ? (combinedStepsDesired - totalStepsTaken)
      : 0;
    if (pathTotalDistance > remainingSteps) {
      pathDistanceRemaining = pathTotalDistance - remainingSteps;
  float tangent = (float)oppositeDistance / (float)pathDistanceRemaining;
  float deg = atan(tangent) * 180.0 / PI;
  desiredBearing100 = (uint16_t)((deg + 90.0) * 100.0);
  if (abs((int)desiredBearing100 - (int)lastSentDesiredBearing100) >= 100) {
    sendDesiredBearing(desiredBearing100);
void updateBearingDiff() {
  bearingDiffTarget = (int16_t)actualBearing100 - (int16_t)desiredBearing100;
  if (bearingDiffRamped < bearingDiffTarget) {
    bearingDiffRamped += 10;
    if (bearingDiffRamped > bearingDiffTarget) bearingDiffRamped = bearingDiffTarget;
  } else if (bearingDiffRamped > bearingDiffTarget) {
    bearingDiffRamped -= 10;
    if (bearingDiffRamped < bearingDiffTarget) bearingDiffRamped = bearingDiffTarget;
void runForwardLoop() {
  if (!navRunning) {
    return;
  if (currentSpeed < normalSpeed) {
    currentSpeed = normalSpeed;
  computeDesiredBearing();
  updateBearingDiff();
  int leftSpeed = currentSpeed;
  int rightSpeed = currentSpeed;
  if (!scanNeutralMode) {
    int correction = bearingDiffRamped / 10;
    leftSpeed -= correction;
    rightSpeed += correction;
  Serial.print("RUN=");
  Serial.print(navRunning);
  Serial.print(" currentSpeed=");
  Serial.print(currentSpeed);
  Serial.print(" bearingDiffRamped=");
  Serial.print(bearingDiffRamped);
  Serial.print(" leftSpeed=");
  Serial.print(leftSpeed);
  Serial.print(" rightSpeed=");
  Serial.print(rightSpeed);
  Serial.print(" scanNeutralMode=");
  Serial.println(scanNeutralMode);
  setAllMotorSpeeds(leftSpeed, rightSpeed);
  LeftFrontWheel.runSpeed();
  LeftBackWheel.runSpeed();
  RightFrontWheel.runSpeed();
  RightBackWheel.runSpeed();
  totalStepsTaken =
    (abs(LeftFrontWheel.currentPosition()) +
     abs(LeftBackWheel.currentPosition()) +
     abs(RightFrontWheel.currentPosition()) +
     abs(RightBackWheel.currentPosition())) / 4;
  if (totalStepsTaken >= nextScanStep) {
    sendObstacleScanRequest();
    scanNeutralMode = true;
    nextScanStep += scanIntervalSteps;
  if (combinedStepsDesired > 0 && totalStepsTaken >= combinedStepsDesired) {
    stopMotors();
    sendTotalSteps(totalStepsTaken);
    resetNavigationState();
// Packet handling
uint8_t getExpectedLength(uint8_t cmd) {
  switch (cmd) {
    case CMD_STOP_MOTORS:    return 0;
    case CMD_ACTUAL_BEARING: return 2;
    case CMD_RIGHT_PIVOT:    return 2;
    case CMD_LEFT_PIVOT:     return 2;
    case CMD_WAYPOINT_DATA:  return 18;
    default:                 return 0xFF;
void pivotRight(uint16_t steps) {
  long positions[4];
  positions[0] = LeftFrontWheel.currentPosition() + steps;
  positions[1] = LeftBackWheel.currentPosition() + steps;
  positions[2] = RightFrontWheel.currentPosition() - steps;
  positions[3] = RightBackWheel.currentPosition() - steps;
  multiStepper.moveTo(positions);
  while (multiStepper.run()) { }
  totalStepsTaken += steps;
  stopMotors();
void pivotLeft(uint16_t steps) {
  long positions[4];
  positions[0] = LeftFrontWheel.currentPosition() - steps;
  positions[1] = LeftBackWheel.currentPosition() - steps;
  positions[2] = RightFrontWheel.currentPosition() + steps;
  positions[3] = RightBackWheel.currentPosition() + steps;
  stopMotors();
void handleWaypointPacket(const uint8_t* data, uint8_t len) {
  if (len != 18) {
    Serial.println("Waypoint length error");
    return;
  pathTotalDistance      = readUInt32LE(&data[0]);
  combinedStepsDesired   = readUInt32LE(&data[4]);
  oppositeDistance       = readUInt32LE(&data[8]);
  bearingAlignment       = data[12];
  desiredBearing100      = readUInt16LE(&data[13]);
  actualBearing100       = readUInt16LE(&data[15]);
  trackDir               = data[17] & 0x01;
  Serial.println("RX: WAYPOINT DATA");
  Serial.print(" pathTotalDistance=");
  Serial.println(pathTotalDistance);
  Serial.print(" combinedStepsDesired=");
  Serial.println(combinedStepsDesired);
  Serial.print(" oppositeDistance=");
  Serial.println(oppositeDistance);
  Serial.print(" bearingAlignment=");
  Serial.println(bearingAlignment);
  Serial.print(" desiredBearing100=");
  Serial.println(desiredBearing100);
  Serial.print(" actualBearing100=");
  Serial.println(actualBearing100);
  Serial.print(" trackDir=");
  Serial.println(trackDir);
  sendNavAck();
  beginForwardNavigation();
void handlePacket(uint8_t cmd, const uint8_t* data, uint8_t len) {
  switch (cmd) {
      stopMotors();
      break;
      if (len == 2) {
        actualBearing100 = readUInt16LE(data);
        Serial.print("actualBearing100: ");
      break;
      if (len == 2 && !navRunning) {
        pivotRight(readUInt16LE(data));
      break;
        pivotLeft(readUInt16LE(data));
      break;
      if (!navRunning) {
        handleWaypointPacket(data, len);
      break;
// UART parser
void processIncomingByte(uint8_t b) {
  switch (parserState) {
    case WAIT_HEADER:
      if (b == UART_HEADER) {
        parserState = WAIT_CMD;
      break;
    case WAIT_CMD:
      currentCmd = b;
      runningChecksum = b;
      parserState = WAIT_LEN;
      break;
    case WAIT_LEN:
      expectedLen = b;
      runningChecksum ^= b;
      if (expectedLen > MAX_PAYLOAD) {
      } else if (expectedLen == 0) {
        parserState = WAIT_CHECKSUM;
      } else {
        payloadIndex = 0;
        parserState = WAIT_PAYLOAD;
      break;
    case WAIT_PAYLOAD:
      payload[payloadIndex++] = b;
      if (payloadIndex >= expectedLen) {
      break;
    case WAIT_CHECKSUM:
      if (b == runningChecksum) {
        handlePacket(currentCmd, payload, expectedLen);
      } else {
        Serial.println("Checksum error");
      currentCmd = 0;
      expectedLen = 0;
      payloadIndex = 0;
      break;
void readIncomingUart() {
  while (Serial3.available() > 0) {
    processIncomingByte((uint8_t)Serial3.read());
// Arduino setup/loop
void setup() {
  Serial.begin(115200);
  Serial3.begin(115200);
  LeftFrontWheel.setMaxSpeed(2000);
  LeftBackWheel.setMaxSpeed(2000);
  RightFrontWheel.setMaxSpeed(2000);
  RightBackWheel.setMaxSpeed(2000);
  LeftFrontWheel.setAcceleration(800);
  LeftBackWheel.setAcceleration(800);
  RightFrontWheel.setAcceleration(800);
  RightBackWheel.setAcceleration(800);
  multiStepper.addStepper(LeftFrontWheel);
  multiStepper.addStepper(LeftBackWheel);
  multiStepper.addStepper(RightFrontWheel);
  multiStepper.addStepper(RightBackWheel);
  Serial.println("ARDUINO_v5 ready");
void loop() {
  readIncomingUart();
  runForwardLoop();
UART_v6 (ARC JavaScript Robot Skill)
var UART_INDEX = 0;
var UART_HEADER = 0xA5;
// ARC -> Arduino
var CMD_STOP_MOTORS = 0x01;
var CMD_ACTUAL_BEARING = 0x03;
var CMD_RIGHT_PIVOT = 0x04;
var CMD_LEFT_PIVOT = 0x05;
var CMD_WAYPOINT_DATA = 0x06;
// Arduino -> ARC
var RSP_NAV_ACK = 0x10;
var RSP_TOTAL_STEPS = 0x11;
var RSP_DESIRED_BEARING = 0x12;
var RSP_OBS_SCAN_REQUEST = 0x13;
// RX parser state
var rxState = 0; // 0=wait header, 1=cmd, 2=len, 3=payload, 4=checksum
var rxCmd = 0;
var rxLen = 0;
var rxIndex = 0;
var rxPayload = [];
var rxChecksum = 0;
function safeInt(v, def) {
  var n = parseInt(v);
  if (isNaN(n)) return def;
  return n;
function clamp(v, min, max) {
  if (v < min) return min;
  if (v > max) return max;
  return v;
function u16ToBytes(value) {
  value = value & 0xFFFF;
  return [
    value & 0xFF,
    (value >> 8) & 0xFF
function u32ToBytes(value) {
  value = value >>> 0;
  return [
    value & 0xFF,
    (value >> 8) & 0xFF,
    (value >> 16) & 0xFF,
function bytesToU16LE(b0, b1) {
  return (b0 & 0xFF) | ((b1 & 0xFF) << 8);
function bytesToU32LE(b0, b1, b2, b3) {
  return (
    (b0 & 0xFF) |
    ((b1 & 0xFF) << 8) |
    ((b2 & 0xFF) << 16) |
    ((b3 & 0xFF) << 24)
  ) >>> 0;
function checksumXor(cmd, len, payload) {
  var c = (cmd ^ len) & 0xFF;
  for (var i = 0; i < payload.length; i++) {
    c ^= (payload[i] & 0xFF);
  return c & 0xFF;
function sendPacket(cmd, payload) {
  var len = payload.length & 0xFF;
  var cs = checksumXor(cmd, len, payload);
  var out = [];
  out.push(UART_HEADER);
  out.push(cmd & 0xFF);
  out.push(len);
    out.push(payload[i] & 0xFF);
  out.push(cs);
  UART.hardwareUartWrite(UART_INDEX, out);
function sendCmdOnly(cmd) {
  sendPacket(cmd, []);
function sendStopMotors() {
  sendCmdOnly(CMD_STOP_MOTORS);
  print("TX: STOP MOTORS");
function sendActualBearing() {
  // You asked for bearing to reflect Servo.getPosition(d17,0) * 100
  // var bearing100 = safeInt(Servo.getPosition(d17, 0), 90) * 100;
  var bearing100 = getVar("$actualBearing100");
  bearing100 = clamp(bearing100, 0, 18000);
  var payload = u16ToBytes(bearing100);
  sendPacket(CMD_ACTUAL_BEARING, payload);
  print("TX: ACTUAL BEARING x100 = " + bearing100);
function sendWaypointData() {
  // Bearing source per your request
  // Build packet values from ARC globals
  var pathTotalDistance = safeInt(getVar("$pathTotalDistance", 0), 0) >>> 0;
  var combinedStepsDesired = safeInt(getVar("$combinedStepsDesired", 0), 0) >>> 0;
  var oppositeDistance = safeInt(getVar("$oppositeDistance", 0), 0) >>> 0;
  var bearingAlignment = safeInt(getVar("$bearingAlignment", 0), 0) & 0xFF;
  // trackDir must be 0 or 1
  var trackDir = safeInt(getVar("$trackDir", 0), 0);
  trackDir = (trackDir === 0) ? 0 : 1;
  // Per your request: both values reflect Servo.getPosition(d17,0) * 100
  var desiredBearing100 = bearing100;
  var actualBearing100 = bearing100;
  var payload = [];
  payload = payload.concat(u32ToBytes(pathTotalDistance));
  payload = payload.concat(u32ToBytes(combinedStepsDesired));
  payload = payload.concat(u32ToBytes(oppositeDistance));
  payload.push(bearingAlignment);
  payload = payload.concat(u16ToBytes(desiredBearing100));
  payload = payload.concat(u16ToBytes(actualBearing100));
  payload.push(trackDir);
  if (payload.length != 18) {
    print("Waypoint payload length error: " + payload.length);
    return;
  sendPacket(CMD_WAYPOINT_DATA, payload);
  print("TX: WAYPOINT DATA");
  print("  pathTotalDistance=" + pathTotalDistance);
  print("  combinedStepsDesired=" + combinedStepsDesired);
  print("  oppositeDistance=" + oppositeDistance);
  print("  bearingAlignment=" + bearingAlignment);
  print("  desiredBearing100=" + desiredBearing100);
  print("  actualBearing100=" + actualBearing100);
  print("  trackDir=" + trackDir);
function sendRightPivot() {
  var steps = safeInt(getVar("$pivotSteps", 0), 0) >>> 0;
  sendPacket(CMD_RIGHT_PIVOT, u16ToBytes(steps));
  print("TX: RIGHT PIVOT steps=" + steps);
function sendLeftPivot() {
  sendPacket(CMD_LEFT_PIVOT, u16ToBytes(steps));
  print("TX: LEFT PIVOT steps=" + steps);
function expectedLengthForCmd(cmd) {
  switch (cmd) {
    case RSP_NAV_ACK:
      return 0;
    case RSP_TOTAL_STEPS:
      return 4;
    case RSP_DESIRED_BEARING:
      return 2;
    case RSP_OBS_SCAN_REQUEST:
      return 0;
    default:
      return -1;
function handleRxPacket(cmd, payload) {
  if (cmd == RSP_NAV_ACK) {
    print("RX: NAV ACK");
    setVar("$navAckReceived", 1);
    return;
  if (cmd == RSP_TOTAL_STEPS) {
    if (payload.length == 4) {
      var steps = bytesToU32LE(payload[0], payload[1], payload[2], payload[3]);
      print("RX: TOTAL STEPS = " + steps);
      setVar("$totalStepsTaken", steps);
    return;
  if (cmd == RSP_DESIRED_BEARING) {
    if (payload.length == 2) {
      var bearing100 = bytesToU16LE(payload[0], payload[1]);
      print("RX: DESIRED BEARING x100 = " + bearing100);
      setVar("$desiredBearing100", bearing100);
    return;
  if (cmd == RSP_OBS_SCAN_REQUEST) {
    print("RX: OBSTACLE SCAN REQUEST");
    setVar("$obstacleScanRequested", 1);
    return;
  print("RX: Unknown cmd=" + cmd + " len=" + payload.length);
function processIncomingBytes() {
  var available = UART.hardwareUartAvailable(UART_INDEX);
  while (available > 0) {
    var b = UART.hardwareUartRead(UART_INDEX, 1)[0];
    available--;
    if (rxState == 0) {
        rxState = 1;
      continue;
    if (rxState == 1) {
      rxCmd = b & 0xFF;
      rxChecksum = rxCmd;
      rxState = 2;
      continue;
    if (rxState == 2) {
      rxLen = b & 0xFF;
      rxChecksum ^= rxLen;
      rxPayload = [];
      rxIndex = 0;
      if (rxLen == 0) {
        rxState = 4;
      } else {
        rxState = 3;
      continue;
    if (rxState == 3) {
      rxPayload.push(b & 0xFF);
      rxChecksum ^= (b & 0xFF);
      rxIndex++;
      if (rxIndex >= rxLen) {
        rxState = 4;
      continue;
    if (rxState == 4) {
      var cs = b & 0xFF;
      if (cs == (rxChecksum & 0xFF)) {
        handleRxPacket(rxCmd, rxPayload);
      } else {
        print("RX checksum error. cmd=" + rxCmd + " expected=" + (rxChecksum & 0xFF) + " got=" + cs);
      rxState = 0;
      rxCmd = 0;
      rxLen = 0;
      rxIndex = 0;
      rxPayload = [];
      rxChecksum = 0;
      continue;
print("UART_v5 started");
while (true) {
  if (getVar("$sendWaypointNow", 0) == 1 && getVar("$waypointSent", 0) == 0) {
    sendWaypointData();
    setVar("$sendWaypointNow", 0);
    setVar("$waypointSent", 1);
  if (getVar("$sendStopNow", 0) == 1) {
    sendStopMotors();
    setVar("$sendStopNow", 0);
  if (getVar("$sendActualBearingNow", 0) == 1) {
    sendActualBearing();
    setVar("$sendActualBearingNow", 0);
  if (getVar("$sendRightPivotNow", 0) == 1) {
    sendRightPivot();
    setVar("$sendRightPivotNow", 0);
  if (getVar("$sendLeftPivotNow", 0) == 1) {
    sendLeftPivot();
    setVar("$sendLeftPivotNow", 0);
  processIncomingBytes();
  sleep(20);
Slide Script by Synthiam
Adjust a numeric variable via slider (0-1000) with customizable min/max, center button and scripts triggered on value change or bonus button press.
Task Script by Synthiam Inc.
Split complex robot tasks into sequential scripts, synchronizing asynchronous skills via NEXT/CANCEL commands for staged automation.
Yes - below is a cleaned-up ARC JavaScript UART_v6 script that matches your ARDUINO_v6 packet format and your clarification about WAYPOINT DATA:
  • $desiredBearing100 is produced by the Arduino and sent back to ARC
  • $actualBearing100 is produced in ARC as Servo.getPosition(d17, 0) * 100
  • For WAYPOINT DATA only, ARC sends both values in the packet, and they are intentionally the same at transmit time
I also corrected a few syntax issues from the pasted draft so it will be valid ARC JavaScript.
UART_v6 ARC JavaScript
var UART_INDEX = 0;
var rxState = 0;
var rxCmd = 0;
var rxLen = 0;
var rxIndex = 0;
var rxPayload = [];
var rxChecksum = 0;
  return n;
  return [
    value & 0xFF,
    (value >> 8) & 0xFF
  return [
    value & 0xFF,
  return ((b0 & 0xFF) |
    ((b3 & 0xFF) << 24)) >>> 0;
  return c & 0xFF;
  var packet = [];
  packet.push(UART_HEADER);
  packet.push(cmd & 0xFF);
  packet.push(payload.length & 0xFF);
    packet.push(payload[i] & 0xFF);
  packet.push(checksumXor(cmd, payload.length, payload));
  UART.hardwareUartWrite(UART_INDEX, packet);
  sendPacket(CMD_STOP_MOTORS, []);
  var bearing100 = safeInt(Servo.getPosition(d17, 0), 0) * 100;
  sendPacket(CMD_ACTUAL_BEARING, u16ToBytes(bearing100));
  setVar("$actualBearing100", bearing100);
  setVar("$actualBearing100", actualBearing100);
  setVar("$desiredBearing100", desiredBearing100);
  var payload = [];
  if (payload.length !== 18) {
    return;
  switch (cmd) {
    case RSP_NAV_ACK:
      return 0;
      return 4;
      return 2;
      return 0;
    default:
      return -1;
    return;
    return;
    return;
    return;
    var b = UART.hardwareUartRead(UART_INDEX, 1)[0] & 0xFF;
    available--;
    if (rxState == 0) {
        rxState = 1;
      continue;
    if (rxState == 1) {
      rxCmd = b;
      rxChecksum = rxCmd;
      rxState = 2;
      continue;
    if (rxState == 2) {
      rxLen = b;
      rxPayload = [];
      rxIndex = 0;
      if (rxLen == 0) {
        rxState = 4;
      } else {
        rxState = 3;
      continue;
    if (rxState == 3) {
      rxPayload.push(b);
      rxChecksum ^= b;
      rxIndex++;
        rxState = 4;
      continue;
    if (rxState == 4) {
      var cs = b & 0xFF;
      } else {
      rxState = 0;
      rxCmd = 0;
      rxLen = 0;
      rxIndex = 0;
      rxPayload = [];
      rxChecksum = 0;
      continue;
print("UART_v6 started");
while (true) {
    sendWaypointData();
    sendStopMotors();
    sendRightPivot();
    sendLeftPivot();
  sleep(20);
Notes
A couple of important ARC points:
  • Servo.getPosition(d17, 0) is correct for ARC JavaScript
  • I kept UART_INDEX = 0 since your Arduino sketch uses Serial3, but the ARC side depends on how you configured the hardware UART in ARC
  • This script assumes the ARC robot skill is using the Hardware UART functions, not the older COM functions
One thing to verify
Your Arduino sketch uses:
  • Serial3.begin(115200);
So in ARC, make sure the UART skill / configuration matches the same baud rate and the correct hardware UART mapping.
Quick sanity check on the packet format
This script matches your Arduino protocol:
  • Header: 0xA5
  • Command
  • Length
  • Payload
  • Checksum XOR of cmd ^ len ^ payload bytes
And it uses these payload sizes:
  • CMD_STOP_MOTORS = 0
  • CMD_ACTUAL_BEARING = 2
  • CMD_RIGHT_PIVOT = 2
  • CMD_LEFT_PIVOT = 2
  • CMD_WAYPOINT_DATA = 18
If you want, I can also do one of these next:
  1. rewrite the Arduino sketch cleanly so it exactly matches this ARC script
  2. verify the packet byte layout field-by-field
  3. convert the ARC script into a reusable robot skill pattern
  4. add debug prints for every incoming/outgoing packet
If you’d like, I can also show you where to place this script in ARC and how to configure the skill from the kebab menu.
@Athena. Here is what I meant to convey:
The function "sendActualBearing()" is sent anytime a new actualBearing is detected, except at initial start when the function "sendWaypointData()" is sent. Waypoint Data (actual bearing and desired bearing) will always be from the same servo position. "sendActualBearing()" will always be a computed bearing from ARC(not a servo position).
 var bearing100 = getVar("$actualBearing100");  //****************************
  var bearing100 = safeInt(Servo.getPosition(d17, 0), 90) * 100;   //**************************
Can you rewrite this code making certain to keep the 'safeInt' and 'clamp' safeguards in place if possible? Thank you. Jack
Absolutely - here’s the clean ARC JavaScript version with your requested behavior preserved:
  • sendActualBearing() uses the computed ARC global $actualBearing100
  • sendWaypointData() uses the same servo position source for both waypoint bearings
  • safeInt() and clamp() are kept in place
  return n;
  return v;
  var bearing100 = safeInt(getVar("$actualBearing100", 9000), 9000);
  var payload = [];
    return;
Important note
Your line:
is fine if you intentionally want a fallback of 90 degrees when the servo position is invalid. If you want the fallback to be a safer midpoint only when the value is missing, this is a good approach.
One small recommendation
Since Servo.getPosition(d17, 0) already returns a commanded position in degrees, using * 100 is correct for your x100 protocol.
If you want, I can also rewrite the full UART_v6 script again with this corrected behavior integrated everywhere so the whole file is consistent.
@Athena. Please rewrite the full UART_v6 script again with this corrected behavior integrated everywhere so the whole file is consistent. Thank you. Jack
Absolutely - below is a full, consistent ARC JavaScript UART_v6 script with your corrected behavior integrated:
  • sendActualBearing() sends the computed ARC global $actualBearing100
  • sendWaypointData() sends both waypoint bearings from the same servo position
  • safeInt() and clamp() are preserved
  • The protocol remains aligned with your Arduino sketch
UART_v6 - ARC JavaScript
var UART_INDEX = 0;
var rxState = 0;
var rxCmd = 0;
var rxLen = 0;
var rxIndex = 0;
var rxPayload = [];
var rxChecksum = 0;
  return n;
  return v;
  return [
    value & 0xFF,
    (value >> 8) & 0xFF
  return [
    value & 0xFF,
  return c & 0xFF;
  if (payload == null) payload = [];
  var checksum = checksumXor(cmd, payload.length, payload);
  UART.hardwareUartWrite(UART_INDEX, [UART_HEADER]);
  UART.hardwareUartWrite(UART_INDEX, [cmd & 0xFF]);
  UART.hardwareUartWrite(UART_INDEX, [payload.length & 0xFF]);
  if (payload.length > 0) {
    UART.hardwareUartWrite(UART_INDEX, payload);
  UART.hardwareUartWrite(UART_INDEX, [checksum]);
  print("TX: cmd=" + cmd + " len=" + payload.length + " cs=" + checksum);
  var payload = [];
    return;
    return;
    return;
    return;
    return;
    available--;
    if (rxState == 0) {
        rxState = 1;
      continue;
    if (rxState == 1) {
      rxCmd = b;
      rxChecksum = rxCmd;
      rxState = 2;
      continue;
    if (rxState == 2) {
      rxLen = b;
      rxPayload = [];
      rxIndex = 0;
      if (rxLen == 0) {
        rxState = 4;
      } else {
        rxState = 3;
      continue;
    if (rxState == 3) {
      rxPayload.push(b);
      rxChecksum ^= b;
      rxIndex++;
        rxState = 4;
      continue;
    if (rxState == 4) {
      var cs = b & 0xFF;
      } else {
      rxState = 0;
      rxCmd = 0;
      rxLen = 0;
      rxIndex = 0;
      rxPayload = [];
      rxChecksum = 0;
      continue;
while (true) {
    sendWaypointData();
    sendStopMotors();
    sendRightPivot();
    sendLeftPivot();
  sleep(20);
Two important notes
  1. Servo.getPosition(d17, 0)
    • This is your waypoint source, and both desiredBearing100 and actualBearing100 are taken from it for the waypoint packet only.
  2. $actualBearing100
    • This remains the computed ARC value used by sendActualBearing() later, not the servo position.
One thing I’d like to confirm
Your draft says:
That’s valid if your servo position is in degrees and you want x100.
Do you want me to also make a matching cleaned Arduino_v6 sketch with the same naming and packet behavior so both sides are perfectly aligned?
@Athena. Please make a matching cleaned Arduino_v6 sketch with the same naming and packet behavior so both sides are perfectly aligned. Thank you. Jack
Absolutely - below is a cleaned Arduino_v6 sketch that matches the packet naming and behavior we’ve been using with your ARC UART_v6 script.
I kept the protocol the same:
  • 0xA5 header
  • command
  • payload length
  • payload bytes
  • XOR checksum
And I aligned the behavior so:
  • CMD_ACTUAL_BEARING is received as a computed bearing from ARC
  • CMD_WAYPOINT_DATA contains both waypoint bearing values from the same servo position source
  • Arduino replies with:
    • RSP_NAV_ACK
    • RSP_TOTAL_STEPS
    • RSP_DESIRED_BEARING
    • RSP_OBS_SCAN_REQUEST
Arduino_v6 Sketch
// ARC -> Arduino
// Arduino -> ARC
enum ParserState
  WAIT_HEADER,
  WAIT_CMD,
  WAIT_LEN,
  WAIT_PAYLOAD,
  WAIT_CHECKSUM
    c ^= data[i];
  return c;
  Serial3.write(cmd);
  Serial3.write(len);
void sendNavAck()
  uint8_t tmp[4];
  uint8_t tmp[2];
void stopMotors()
  currentSpeed = 0;
  navRunning = false;
  navRunning = true;
  currentSpeed = 0;
    return;
  if (trackDir == 0)
  else
    uint32_t remainingSteps = (combinedStepsDesired > totalStepsTaken) ? (combinedStepsDesired - totalStepsTaken) : 0;
  if (!navRunning)
    return;
  long positions[4];
  positions[0] = LeftFrontWheel.currentPosition() + 1;
  positions[1] = LeftBackWheel.currentPosition() + 1;
  positions[2] = RightFrontWheel.currentPosition() + 1;
  positions[3] = RightBackWheel.currentPosition() + 1;
  totalStepsTaken++;
    stopMotors();
  switch (cmd)
  long positions[4];
  stopMotors();
  long positions[4];
  stopMotors();
  if (len != 18)
    return;
  sendNavAck();
  switch (cmd)
      stopMotors();
      break;
      if (len == 2)
        Serial.print("RX: ACTUAL BEARING x100 = ");
      break;
      break;
      break;
      if (!navRunning)
      break;
    case WAIT_HEADER:
      break;
    case WAIT_CMD:
      currentCmd = b;
      break;
    case WAIT_LEN:
      expectedLen = b;
      else
        payloadIndex = 0;
      break;
    case WAIT_PAYLOAD:
      break;
    case WAIT_CHECKSUM:
      else
      currentCmd = 0;
      expectedLen = 0;
      payloadIndex = 0;
      break;
void setup()
  Serial.println("ARDUINO_v6 ready");
void loop()
  readIncomingUart();
  runForwardLoop();
A couple of things to verify
  • Serial3 wiring on the Mega is correct:
    • ARC TX Mega RX3
    • ARC RX Mega TX3
    • GND common between both
  • Baud rate matches on both sides: 115200
  • The ARC script and this Arduino sketch both use the same packet format and command IDs
One important note
Your current Arduino sketch calculates waypoint bearing from:
  • pathTotalDistance
  • combinedStepsDesired
  • oppositeDistance
  • bearingAlignment
  • trackDir
That means the ARC side only needs to send valid values for those fields, plus the bearing pair.
If you want, I can now do one of these next:
  1. clean the ARC UART_v6 script again one last time
  2. merge both scripts into a final verified pair
  3. add a packet-by-packet test sequence for ARC and Arduino
  4. review the math for computeDesiredBearing() and updateBearingDiff()
If you'd like, I can also format both scripts into a copy/paste-ready final version with no explanatory text.
@Athena. Please review the math for computeDesiredBearing() and updateBearingDiff(). Thanks. Jack
