OK guys I have another question for everyone can you use the UART on the EZB V4 to connect to a USB rather than the camera port?
I want to hardwire my EZB's to my onboard PC but I also want to use my ez-robot camera with one of my EZB V4.
BN-880 GPS Compass
— Standalone autonomous navigation using Beitian BN-880 GPS/Compass with real-time map waypointing and offline map caching; requires Arduino.
I can't find a video connecting a camera to the IoTiny, but here's a picture of where it connects (labeled Camera). The EZ-Robot EZB v4 also has a similar camera port, which I believe you know because you're using that for USB PC connectivity. The IoTiny camera port doesn't do USB connectivity because of some hardware limitations.
Here you go - this is a good option if you need a low cost small USB camera: https://www.amazon.ca/Camera-Module-Interface-HBV%E2%80%91W202012HD-Android/dp/B08MQJVY8T
It's $13
Ah, okay - so back on the EZ-Robot camera to USB. So if that's the case, then the information I had provided was about the RTS pin because the camera will not transmit unless the RTS is low.
But as Jeremie pointed out, while the EZ-Robot camera is UART and will work with a USB adapter, it is 3,333,333 bps. Most USB UART adapters might not support that speed. The thing is, with the massive number of USB cameras, the EZ-Robot camera was never designed to be connected by USB. It's a camera UART intended for the EZ-Robot EZB v4 and IoTiny. Your hack "might" get it to work if you can find a UART USB adapter that supports 3,333,333 bps.
But I think you'll be better off with that USB camera.
OK DJ another question if it was you would you use the IoTiny and camera over a wifi connection to ARC or a USB camera connected to the LattePanda?
Usb all the way. I’m not one to hack something when there’s a perfectly good component meant for the job. I value my time to be building and programming.
I wouldn’t use an iotiny either. Because it doesn’t have usb capability.
id just use the ezb v4s. And if I needed a small controller for the head, I’d probably use an ardunio or maestro from polulu now that there’s a skill for it.
you can get a polulu maestro that does 6 8 12 or 24 servos etc.
oh ps, I shouldn’t add that another reason to use usb camera. It means one less thing to diagnose. If something goes wrong, it’s nice to know you won’t have to worry about the hack job on the camera. All the little things add up when stuff doesn’t go right haha
Ok DJ I here you I will be ordering a USB camera and I will save the IOTiny for another build.
I am going to use the LattePanda in the head and the EZB4 for the rest of the build. I may use something else. For the hands but I need to get to that point in the build. I really would like to develop a better hand for my build if I can that may require more servos then the current design.
DJ I also really appreciate all your feedback and wanted to make sure I thanked you.
Anytime. I am curious with Jeremie’s findings. I remember him and I did it before with our inmoov and an ezrobot camera. He had to find a uart usb that worked for high speed.
although you could make your own with an stm32 lol
actually an arduino could do it if it has hardware uart. An esp32 for sure cause it’s based on stm32
